Clearing HT hold down :shock:
nemmi69
Posted: Thu Nov 22, 2007 4:07 pm    Post subject: Clearing HT hold down :shock:
I have a problem in that IRIS made a crap picture which shut down seconds later on HT hold down (according to the LEDs on the front). Any one know how to get the 708 to come out of it so we can reset it?
What doesn't kill you is only biding it's time
Posted: Thu Nov 22, 2007 4:11 pm    Post subject:
Those should be two unrelated problems. Does the set work without using the IRIS? The IRIS shouldn't cause HD hold down.
nemmi69
Posted: Thu Nov 22, 2007 4:15 pm    Post subject:
The IRIS just created a setup that caused the problem it isn't the reason its staying that way. The set comes on and the line LEDs are green but the hold down LED is amber.
Fujifrontier
Posted: Thu Nov 22, 2007 4:43 pm    Post subject:
What is Hd hold down?
Posted: Thu Nov 22, 2007 4:46 pm    Post subject:
The hold down light shouldn't be amber, it is red. THe amber light simply means that a memory location in the projector is being used by the current input signal. that's normal, and isn't a fault indicator. Are any red lights lit up in that row of lights?
http://www.curtpalme.com/Barco701_Layout3.shtm
nemmi69
Posted: Thu Nov 22, 2007 5:01 pm    Post subject:
A tpyo Wink
Fujifrontier
Posted: Thu Nov 22, 2007 11:42 pm    Post subject:
LOL. I wasn't being sarcastic, I wanted to know what the term meant.
High voltage shutdown?
Posted: Fri Nov 23, 2007 12:17 am    Post subject:
The hold down HD is a shutdown of the HTHD supply. This can be caused by the deflection board or by a bad focus board.
(a click on the above link would have given it to you..Wink)
nemmi69
Posted: Tue Nov 27, 2007 3:59 pm    Post subject:
Sorry the HD LED was red but that is not on. I have all green now apart from the far right which is amber. Can see that the rear of the tubes some energy as there is a glow (is this the heaters?) but now colour at the front. Not sure this makes it clear at all Rolling Eyes
nemmi69
Posted: Mon Dec 03, 2007 4:46 pm    Post subject:
Well Checked the information
All the left LEDs are green, no red LEDs and the far right (COINC) is amber. I have been trying to find the + conv fuse to see if thats blown but can't seem to locate it. You can see that the heaters are on on the tubes.
PS - Fujifrontier: HD means Hold Down of the HT supply.
Posted: Mon Dec 03, 2007 4:53 pm    Post subject:
If all lights are green, then the + conv fuse is fine.
If you still do not have a picture, then I would suspect a problem on the video input board. Those have all sorts of possible faults on them that can cause a no picture condition even though there are no fault LEDs lit on teh front of the set.
nemmi69
Posted: Thu Dec 13, 2007 2:02 pm    Post subject:
The latest so far is that on the deflection board there is a red LED that flickers when I select "1" and again when i put the unit back in to stand by.
I also noticed on the video input board that non of the green lights come on at all in response to selecting "1".
nemmi69
Posted: Thu Dec 13, 2007 2:05 pm    Post subject:
Embarassed Sorry, its not the deflection board its the H & V board. There is also a smaller LED lower down that flickers to.
nemmi69
Posted: Thu Dec 13, 2007 8:14 pm    Post subject:
just tried using the RGBS inputs but still no response from the lights on the video input board. still no picture from the tubes. Any guesses whats going on?
nemmi69
Posted: Mon Jan 07, 2008 4:20 pm    Post subject:
Found that if you are patient (not my forte) then the input board lights do active the the appropriate input. Still doesnt give a picture though. Did notice that all the G2 LEDs are on but I guess thats due to a lack of HV.
Posted: Mon Jan 07, 2008 4:35 pm    Post subject:
I'm guessing that it's the video input board. At this point you need to pull the board and send it in, I can't troubleshoot it further than that without seeing it.
