howelljim44
| Posted: Wed Nov 21, 2007 4:29 pm Post subject: Mitsubishi HD1080 HDTV (Rear Projection) w/HD Fury |
I have a Mitsubishi HD1080 Diamond Series HDTV (Rear Projection) Model VS-50803 with the 5 BNC connectors (RGBHV) for attaching a Mitsubishi HD Receiver. Is there anyone out there that has successfully connected the Green HD Fury successfully on this particular model of HDTV (or any rear projection HDTV model with these connectors)?
I would like to attach a Toshiba HD-DVD player. Eventually, I'd like to connect the HD-DVD, a ScientificAtlanta Explorer 8300HD Receiver and a Blu-Ray Disc player to the HD Fury via a HDMI switch.
The folks at HKMod.com recommended I contact you for GREEN edition support. They also indicated that the Afaik Mitsubishi projector has a known issue with the image centering.
Thanks very much!
_________________ Jim Howell
| Posted: Wed Nov 21, 2007 6:52 pm Post subject: |
The RGBhv input (whether the physical is BNC or RCA) shouldn't matter one bit. I have a Diamond 65907 and instead of BNC connectors they are RCA style. I can configure the input for Component 1080i or RGBhv 1080i. While I do have the HDfury, I have not tried it out on that RPTV.
BTW, I thought the Toshiba HD DVD players also had Component output as well. Does your Diamond have a configurable (shared) YPbPr/RGBhv input, or is it absent on the HD Component?
howelljim44
| Posted: Wed Nov 21, 2007 7:12 pm Post subject: |
Hey WanMan,
The Toshiba HD DVD player does have Component output. However, my Diamond has separate Component and RGBhv inputs. The Component input is limited to 480P. Using the Component connection, neither the HD DVD or the SA Explorer 8300HD will work.
I was also told by the local Mitsubishi dealer (Audio Warehouse) to use RCA to BNC adapters on the component cable to connect to the RGB inputs. They thought it would work without the HV cables, but the TV didn't recognize the signal, and the picture was blank.
BTW - the RGBhv connection was meant for the Mitsubishi HD Receiver, which also has a "control" cable (I think it's a DB9). The Mitsu HD Receiver has no extra inputs for external devices, so there's no point buying one. Although, I wondered if the RGBhv connection would work without the "control" connection, or is that simply an interface between the HD Receiver similar to the Home Theater or IR Link connection?
Thanks for your help!
| Posted: Wed Nov 21, 2007 7:47 pm Post subject: |
I do not know what year your unit was manufactured, but I bought mine at the end of 2000--before Mitsubishi had an HD receiver. In fact, I thought when they came out with a DTV receiver for sold RPTV units the offer for those owners was an integrated digital receiver solution that required a service call.
I've successfully used the same physical inputs for RGBhv (vai RCA DTC-100 DirecTV/OTA) and YPbPr (Xbox 360). There is no control connection that I am aware of on my RPTV. I'd go into the RPTV's setup and configure the DTV input and see if it offers Component (YPbPr).
| Posted: Wed Nov 21, 2007 7:53 pm Post subject: |
Jim,
Googling turned up this forum thread:
http://www.highdefforum.com/showthread.php?t=1865
Looks like there are plenty of guys that got that very set working with the RGBHV connection and 1080i devices. Looks like you need to do something with a service menu to force the input to "DTV", which I assume forces the set to synch to 1080i only, and then make sure that your source is 1080i and 1080i only.
Given all that, I'd guess the HD Fury will work, provided your source(s) are set to 1080i - just as the other devices in that thread. I think it's certainly worth a try. You could always sell the HD Fury for close to what you paid for it on this very forum - especially with the RGBHV adapter. Might cost you $20 or $30 to give it a whirl.
howelljim44
| Posted: Wed Nov 21, 2007 8:52 pm Post subject: |
Hey guys,
Thanks for the quick responses.
WanMan: My RPTV was manufactured in 1998. When Mitsubishi offered the DTV Receivers I had the choice of a set-top box or an internal upgrade. At the time, both options cost $600, and I couldn't even subscribe to HD Programming from my cable company. And BTW, my TV is one of the early HDTV's from Mitsu.....50" 4:3 config.
ecrabb: Thanks for the link and your input. I haven't actually purchased the HD Fury yet--I wanted some assurance it would work without the shifting problem some folks have on projectors. I have no shift adjustment on this TV.
Thanks again!
| Posted: Thu Nov 22, 2007 1:31 am Post subject: |
Jim, there may be a shift adjustment in the service menu. I'm not sure however how to axcess that.
Sooooooooo I fired up the Gooling gun and found this:
http://www.imagingscience.com/cal-lib/mitsu508xx.htm
Calibration For Mitsubishi HDTVs
VS-50800/VS-50803/VS-60803
contributed by contributed by Mike Wood, Curtco Media Group, mwood@curtco.com
snipped..........
To Enter the Service Mode
With the set turned on, press the Menu button once.
Press the buttons 2, 3, 5, and 7 in sequence.
The screen will change and the service mode will come up.
Use the Audio +/- buttons to cycle through the various adjustment functions. (If you’re using the new remote, you can only cycle in one direction. The menu will loop from the last category back to the first.) The current function is displayed in the top left corner of the menu.
"Video Chr" is used for adjusting color temperature, DC restoration, front panel controls, and color decoder settings.
"Iris" is used for adjusting the IRIS control.
"Deflection Jungle" is used to adjust geometry.
Use the Video +/- buttons to cycle through the various adjustments within each function. (Again, with the new remote you can only go forward, and must wait for the menu to loop back to the beginning.) The adjustment is a number listed in the lower left corner of the menu. The name of the adjustment is to the right of this number.
Basic Service Menu Controls
1 SCT Picture Gain Control
2 SBRT Sub Brightness
3 SCOL Sub Color
4 STIN Sub Tint
5 SCON Sub Contrast
18 BRT Bright control
19 COL Color Gain control
20 TINT Tint Control
21 CONT Picture Gain Control (This did not exist on my sample)
22 SHRP Sharpness
23 SSH1 Sub Sharpness (0 is off, 3 is on high)
33 DCT DC Restoration (0 is most, 3 is least)
55 VMSW SVM on/off (This had little or no effect on my sample)
snipped again...................
Start with the geometry controls in the "Deflection Jungle". Use the above service code and press Audio until "Defl Jung" appears.
1 HWID Horizontal Width
2 HKEY Horizontal Keystone
7 VHGT Vertical Height
8 VSCN Vertical S-Correction
9 VLIN Vertical Linearity
10 VLNT Vertical Linearity on top
11 VLNB Vertical Linearity on bottom
14 HPOS Horizontal Position (Keep this value at 34 for NTSC and 35 for HDTV)
15 BLKL Blanking left side
16 BLKR Blanking right side
17 BLKT Blanking top
18 BLKB Blanking bottom
20 VPOS Vertical Position
29 ASPT Aspect Ratio
42 BOW Bow
| Posted: Thu Nov 22, 2007 2:16 am Post subject: |
AR, what was your search keywords in Google to find this? I am curious if its different for my WD-65907. I wonder where the overscan function is.
Gosh, now you got me looking. This one location has a ton of info for sale: http://www.icxinyi.com/EN/zlsearch.php
If I could just get them to make me some [leaded] $50 replacement tubes ...
| Posted: Thu Nov 22, 2007 6:42 am Post subject: |
| WanMan wrote: | AR, what was your search keywords in Google to find this? I am curious if its different for my WD-65907. I wonder where the overscan function is.
If I could just get them to make me some [leaded] $50 replacement tubes ...  |
Hmmm I can't remember for sure. That was hours ago . Probably something like "service menu Mitsubishi (model number )" That info was the first one on the list.
| Posted: Thu Nov 22, 2007 6:46 am Post subject: |
Just like this:
BTW did you kow if you have a Sencore color analizer you are entitled to access Sencore's Color Calibration Library web site?
http://www.sencore.com/newsletter/May02/Instrumentally%20Issue%205_02.htm
snipped........................................
Mitsubishi Service Menu Access Codes
As long as we are discussing Mits, here is a table of activation codes for recent Mitsubishi RPTVs. Each of these codes is preceded by a press of the MENU button on the remote (V19 Adjustment Menu = "MENU-0-1-5-7"). When in the Convergence mode, the 6, 5, and 4 buttons on the remote select Misc, Coarse, and Fine adjustment modes.
Chassis
VZ5
VZ7
VZ9
Aspect Ratio
4:3
4:3
4:3
VS-45603
VS-45605
VS-45609
VS-50603
VS-50605
VS-50609
VS-50604
VS-50705
VS-55609
VS-50703
VS-55705
VS-60609
VS-60603
VS-60705
VS-60719
VS-60703
VS-70705
VS-70709
VZ6
VZ8
V18
4:3
4:3
16:9
VS-50800
VS-45607
WS-55809
VS-50803
VS-50607
WS-65809
VS-60803
VS-60607
WT-46809
VS-70803
VS-50707
WS-55819
VS-80803
VS-55707
WS-65819
VS-60707
VS-70707
V15
V16N
V17
V19
16:9
4:3
16:9
16:9
WS-65903
VS-50805
WT-46807
WS-55859
WS-73903
VS-60805
WT-55807
WS-65869
WT-65807
WS-55909
V16W
WS-55857
WS-65909
16:9
WS-65857
WS-73909
WT-46805
WS-55907
WS-55805
WS-65907
WS-65905
WS-73907
WS-73905
WS-55908
WS-65908
MENU/MODE
Option
1-3-7-0
1-2-7-0
1-2-7-0
0-1-7-0
Adjustment
2-3-5-7
1-2-5-7
8-2-5-7
0-1-5-7
Convergence
2-3-5-9
1-2-5-9
8-2-5-9
0-1-5-9
