1209s - EHT blows the 2A fuse....
Rittberg
Posted: Wed Nov 21, 2007 8:36 am    Post subject: 1209s - EHT blows the 2A fuse....
The picture on the 1209s suddenly goes blank,
All the green leds on the G2 are on.
The red led on the EHT was red.
Powered the PJ again, reduced the contrast to 30% - works for few minutes and it goes blank.
Started again, the PJ was working but continue to be blank, at this time the red led was off.
So I go to the the EHT board , the fuse was blown.
Replaced the fuse and the EHT keeps blowing the fuses.
When the Quad's connector (with the 4 thin wires) was disconnected the EHT fuse doesn't blow,
So what goes bad?
Posted: Wed Nov 21, 2007 2:01 pm    Post subject:
What is the quadrupler part number that you put into the set (I got your email, but will answer here).
The EHT board is blown, the circuit to the fuse is disconnected when you pull that white plug. I want to make sure the quad is the right one. If so, it's probably just the EHT board that is bad, I've got spares or can repair yours.
Rittberg
Posted: Wed Nov 21, 2007 2:28 pm    Post subject:
R762833
Thanks.
Posted: Wed Nov 21, 2007 3:02 pm    Post subject:
OK, that's the right one. I'd say all the problem is is the EHT board. I'll email you..
