How to remove stripped screw from the back of a Vision One?
sdvette
Posted: Mon Nov 19, 2007 1:38 am    Post subject: How to remove stripped screw from the back of a Vision One?
Well today while I was trying to install my moome card into my vision one I ended up stripping one of the tiny screws that hold the metal plates that covers the open bay that it goes into. Does anyone have any ideas how to get the screw out??
thx
Jim
Posted: Mon Nov 19, 2007 2:17 am    Post subject:
Something like this may help:
http://www.canadiantire.ca/browse/product_detail.jsp?FOLDER%3C%3Efolder_id=1408474396672926&bmUID=1195438379368&PRODUCT%3C%3Eprd_id=845524441899731&assortment=primary&fromSearch=true
or if your stateside:
http://www.sears.com/shc/s/p_10153_12605_00966202000P?vName=Tools&keyword=screw+extractor
Posted: Mon Nov 19, 2007 2:25 am    Post subject:
If you snapped the head then you will need an EZout as AR said
However if you only stripped the screw and didn't break off the head you should be able to grab it with a pair of vise-grips and pull it out.
I don't think you would get anywhere with an EZout if you really stripped the screw as it would just spin in the hole as you drilled and tried to EZout it out.
Erik
Picture would help Wink
mack1
Posted: Mon Nov 19, 2007 3:34 am    Post subject:
try turning the screw with ascrew driver while prying under the head of the screw with a small thin flate screw driver.this has worked for me in the past Thumbs Up
JustGreg
Posted: Mon Nov 19, 2007 3:40 am    Post subject:
Beat me to it. Laughing The screw only needs to be raised enough to grab the next course of thread. You may even get lucky and still be able to use the screwhole. The screw obviously is trashed because it'll have a spot with no threads. Hopefully you won't have to drill and tap and put an oversized screw in. Lotsa metal filings. Thumbs Down
Greg
Posted: Mon Nov 19, 2007 3:49 am    Post subject:
zaphod
Posted: Mon Nov 19, 2007 2:13 pm    Post subject:
this tool will lift up the screw to the next threads.
http://www.leevalley.com/hardware/page.aspx?c=1&p=32058&cat=3,41306,41329
Posted: Mon Nov 19, 2007 3:30 pm    Post subject:
Hello
You want to determine if the threaded insert has separated from the sheet metal of the frame and is spinning with the screw stuck in it; the most you can do is hope to remove both
CZ Eddie
Posted: Wed Nov 21, 2007 2:38 am    Post subject: Re: How to remove stripped screw from the back of a Vision O
thx
Jim
Pull on the plate while unscrewing. The plate will pull the screw towards you, helping it along out of the threads.
