Checking P14 Filament voltage - no reading?!
PaulB
Posted: Sat Nov 17, 2007 4:13 pm    Post subject: Checking P14 Filament voltage - no reading?!
I must be doing something dumb here.
I just tried to check the P14 voltage on my 9500 but I'm not getting any reading at all! I've disconnected the P14 plug and attached one clip to one pin and the other clip to the other pin then powered up the pj and ..... nothing, the multimeter doesn't budge off of zero!
I checked the multimeter and clips by using a torch battery I had lying around and it read that ok but I'm just not reading anything off of P14! Multimeter is set to DC Voltage (just like Tim's photo here http://www.etechvideo.com/a4p1.htm ) but nothings happening.
Any idea guys? It has to be me thats doing it wrong but I can't see how. PJ works fine otherwise.
Thanks guys,
Paul
Posted: Sat Nov 17, 2007 6:07 pm    Post subject:
Hello
Reconnect the wire, the voltage comes from the wire.
PaulB
Posted: Sat Nov 17, 2007 6:14 pm    Post subject:
Tim, you're a star!!
4.4 in standby, 6.9 on full power! Looks like the LVPS fix will be getting done on Monday!
A thought, as the tubes look good, does the filament fix mean that they will still last their full 8-10,000 hours or will their life have been shortened due to the high voltage?
Paul
Posted: Sat Nov 17, 2007 11:28 pm    Post subject:
Paul
Hello
It depends.......6.9vdc is high, but what are the tube hours? Add viewing hours to standby hours, the filament stays full on in standby.
Joust
TV/Projector: Marquee 8501LC
Posted: Sun Nov 18, 2007 12:25 am    Post subject:
Paul
is that measurement on the disconnected plug? or while its connected?
If its on the disconnected, then that is probably fine because that is an unloaded measurement in that case.
Measure it when its connected. to adjust it properly.
PaulB
Posted: Sun Nov 18, 2007 4:37 am    Post subject:
Tube hours;
CRTs On 5988
Standby 7150
Measured when connected (unfortunately). Now reduced to 6.35 by using the existing pot.
Red only just installed so it won't have any issues, blue and green MAY be original but just a guess as they look perfect otherwise.
Paul
