how far back for a G90
sdvette
Posted: Mon Nov 12, 2007 4:23 am    Post subject: how far back for a G90
My G90 is getting mounted this Wed. What is the correct distance for a 16x9 screen that is 120inch diagonal. I think its 96inches wide by 54 high.
thx,
Jim
Chuchuf
Posted: Mon Nov 12, 2007 10:30 pm    Post subject:
Download a copy of PJCalc 3.2 or newer and use it to determine your throw distance. It will be close.
Terry
bomrat
Posted: Tue Nov 13, 2007 10:29 am    Post subject:
set it up on the floor and measure, its the best way to ensure max raster useage.
Frank D
Posted: Wed Nov 14, 2007 2:05 am    Post subject:
Going from memory here but perhaps someone else can verify this too:
If you want to maximize the phosphor usage to get maximum light output - I think it is about 1.25 x screen width.
My G90 is set up about 115.5 inches for my 92" wide X 52" high 16:9 screen - from screen to center of green gun front glass lens.
PJ calc is not set up for max phosphor usage and therefore should give you a farther measurement (ie less phospor usage).
sdvette
Posted: Tue Nov 20, 2007 6:22 am    Post subject:
I did the PJ Calc and it looks like it needs to be 141 inches back for my screen. Seems pretty close. Any exerience if I put it further back I would use more of the CRTs?
papalek
Posted: Tue Nov 20, 2007 10:42 am    Post subject:
The farther back the LESS usage of the phosphors. Crying or Very sad
I do love my AmPro's
Posted: Tue Nov 20, 2007 11:45 pm    Post subject:
Rule of thumb is 7% closer than PJCalc-uhhh-calculates.
sdvette
Posted: Wed Nov 21, 2007 6:03 am    Post subject:
really 7%..that would put me somewhere in the 131 range.. does that sound right for a 16x9 120"screen. I think the actual measurements are 104 inches wide by 54 inchs high. The bottom of the CRTs will be within about an 1 or 2 of the top of the screen...so I think that with the inch or so on the mount I will be almost right on...but am very concerned with getting the distance correct..anyone have PJ Calc and can verify my numbers including coming 7% closer would be great...
sdvette
Posted: Thu Nov 22, 2007 6:42 pm    Post subject:
anyone??? This thing goes up on Monday and I would really love it if one of the people in the know could validate my numbers?
thx,
Jim
nuttall_chris
Posted: Thu Nov 22, 2007 8:11 pm    Post subject:
I think this has been posted about 1000 times....point it at a wall, max the raster and measure the distance from the wall to get your required screen size.
Chris.
