Sony VPH-1251 troubles
Abpel
Posted: Sat Nov 10, 2007 9:44 pm    Post subject: Sony VPH-1251 troubles
Hi there CRT-guru's and soon to be's.
After lurking around for some time here, i decided it was time for me to get a CRT.
A vph-1251 was bought, and i bought a supra 5BNC-cable. I allready had a HTPC, which i am using as the source.
Haveing a shortage of time, i didnt really ever get any further then putting it on a table and fooling around with it. I got some very (for me) ok images out of the projector this way.
Yesterday i decided it was time to mount it on the ceiling. So some friends and i got a mount and hung it on the ceiling. While connecting the projector to the mount we had to lay it on its back. This is the moment where i heard a crack. Thinking it was just the case that something happened to, we continued.
Before mounting it, i changed all the plugs on the DC and Eboard so that the image would be displayed properly.
Now though, the image is all distorted. Its flikkering, and i cant make out anything on the screen that would be the desktop of the htpc.
The crack seems to actually have been the case, since it was a bit loose after isntallation, and i could find no visual dammage anywhere.
I dont think my description of the problem is very usefull, so ill try and take some pictures tomorrow or so.
Anyone got any ideas of how to fix this? i want total blackness Smile
Thanks in advance
tony359
Posted: Sun Nov 11, 2007 2:16 am    Post subject:
I layed my 1271 on its back too but with no cracks!
Check for all connectors and check for damage on card. Reseat all cards.
Ciao
Antonio
Abpel
Posted: Sun Nov 11, 2007 10:08 am    Post subject:
Probably a noob question, but which cards would that be? Not all electrical boards in the projector i hope.
I've just checked all cable-connections visible with the hood removed, and that didnt solve it.
Abpel
Posted: Sun Nov 11, 2007 11:29 am    Post subject:
I think i have reduced the problem to two options: It's either the supra cable that has an internal break, or a board that handles the RGB connectors in the projector has been broken.
I came to this conclusion since i do get an image when i hook up a dvdplayer with a svhs cable.
Anyone have any ideas on how to check which of the 5 cables was broken, and how i could repair this? Thinking its one of the sync cables, since no steady viewable image appears on the screen.
AvgOrdinaryGuy
Posted: Sun Nov 11, 2007 1:42 pm    Post subject:
Try pulling the RGBHV input board out of the projector, and then firmly reseat it. Might accomplish nothing, but then again it might just fix the problem.
Abpel
Posted: Sun Nov 11, 2007 1:58 pm    Post subject:
Thanks for the help but ive found the sollution to this problem and its a very simple one: Dont connect the bnc connectors to the wrong connectors on the projector!! Very simple and stupid as you can read.
tony359
Posted: Mon Nov 12, 2007 1:00 am    Post subject:
Smile Smile
Well, glad that this has been solved this way! Smile
Ciao
Antonio
