Unbalanced Output to Balanced Input
Posted: Wed Nov 07, 2007 10:55 am    Post subject: Unbalanced Output to Balanced Input
I thought I remember reading something a couple of years back about how to modify balanced cable to accept an unbalanced signal. When I say 'balanced cable' I mean a cable designed to be used with balanced processor and amplifier. Something about terminating one of the cable's conductors to ground.
Anyone done this? Anyone know what the hazards might be (to the amp or processor) when feeding an unbalanced signal from the processor to a balanced amplifier?
papalek
Posted: Wed Nov 07, 2007 12:08 pm    Post subject:
The connection has 3 wires +,-,ground. From what I have seen,you cross the negative with the ground. If you don't cross them the amp will only put out half of its power.
I do love my AmPro's
Posted: Wed Nov 07, 2007 3:03 pm    Post subject:
Connect the negative with the ground, and use that as the ground/common connection.
Posted: Thu Nov 08, 2007 10:20 am    Post subject:
Well, now that was easy. Smile
Posted: Fri Nov 09, 2007 2:00 am    Post subject:
You need one of these:
 Filesize:  106.27 KB
 Viewed:  5843 Time(s)
Posted: Fri Nov 09, 2007 10:55 am    Post subject:
If it comes in the form of a 90-pound Phillipina nymphomaniac then I'm with you!
