Yo Curt.. have you seen this problem...
Posted: Tue Nov 06, 2007 4:32 pm    Post subject: Yo Curt.. have you seen this problem...
I'm having a problem on my shop (test unit) 8500 Ultra.
The problem is IC 'U900' on the vertical deflection board. I've replaced that IC about 4 times. I've swapped out the board twice. I've even replaced the yoke that it connects to.
Whatever I do, it seems to keep blowing that IC, and when it does, it also takes out resistor 'R920'.
I'm running out of the chips, and I don't want to put in another VDM until I can get to the bottom of this.
I've checked the heatsink and the clip that holds the chips to the heatsink. I've also looked at the isolator, but did not notice anything unusual.
Help!
Posted: Tue Nov 06, 2007 4:47 pm    Post subject:
Hm, no, but let me check the schematic. The only thing I had happen on one MArquee that took out a number of HDMs was a ground strap that came loose on the bell of one tube, causing HV arcing, not very loud, but enough to take out the HDM FET a few times before I heard the 'tick' of the HV arc...
Posted: Tue Nov 06, 2007 6:10 pm    Post subject:
Say Mike
Put a meter from the IC tab to ground, maybe the insulation tape is scuffed; were you swapping boards on the heat sink?
oliverg
Posted: Tue Nov 06, 2007 6:26 pm    Post subject:
Mike - from what I've seen, the Electrohome boards are all very susceptible to flashover.
Over the years, safeguards have been adopted and seemingly each revision and ISS have more and more field mods to make them more robust. Is this a manifestation of a similar problem?
Kind regards
Posted: Tue Nov 06, 2007 6:58 pm    Post subject:
WEll the Ulta is about as late a board set as you can get. The only time I've seen a smoked V board is usually when someone (me included) does something wrong when doing the anamorphic squeeze mod.
Posted: Tue Nov 06, 2007 7:22 pm    Post subject:
I got it working again!!!
But I doubt that I've solved the original problem.. Sad
I think I'm safe as long as I don't put the heatsink back up and screw it in place. Not sure what's causing this. and I don't want to risk blowing another IC, though this last time it was only the 1 ohm resistor.
The insulator looks OK, and I've even poked it with the probe of my Fluke hoping to read short/leaking along its surface - nothing!
For now..Mr. Green
Posted: Tue Nov 06, 2007 7:39 pm    Post subject:
Also check to see that the plastic strip between the heatsink and motherboard connectors is in place. Flipping that heatsink up with the strip punctured or being loose can cause the multipin connector to short to the heatsink assembly. HAd that happen once.
JustGreg
Posted: Tue Nov 06, 2007 8:00 pm    Post subject:
I'd modify line conditioners....it's possible you're the victim of a diabolical underground resistance group who surreptitiously directs nano bots (Digital Disease) to seek out analog devices capable of producing results superior to those of their creator, King Xenon, and destroying the victim from within via an overwhelming mass of
1010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101
Or, it could just be a flaky ground. Mr. Green
It almost sounds like the flexing problems that goes on with the X clamp on an XB360.
Greg
Posted: Tue Nov 06, 2007 8:02 pm    Post subject:
That was my first thought, but the connector on the Ultra's mother board is different (see below).
Posted: Tue Nov 06, 2007 8:09 pm    Post subject:
One day I'm going to get me one of those things that those strange folk use to detect ghost in buildings. It seems that they use a Fluke meter attached to a coil of wire...
I think once I do that, I'm sure I'll get to the bottom of things, because it must be ghost shorting out those IC's. I just need to figure out what to set the Fluke to, and what gauge of wire to use to connect to the coil of wire..Very Happy
Posted: Tue Nov 06, 2007 11:21 pm    Post subject:
I think that's the same batch of ic's that AmPro's QC team rejected Laughing
Posted: Wed Nov 07, 2007 1:15 am    Post subject:
what's an Ampro??
Posted: Wed Nov 07, 2007 1:50 am    Post subject:
mp20748 wrote:
what's an Ampro??
Well, if a G-90 is a Cadillac and a Marquee is a lincoln, A AmPro is a Rolls Royce 8)
Posted: Mon Nov 26, 2007 12:53 pm    Post subject:
A couple of weeks and the last two days mainly devoted to this problem and BINGO!
last night around 9PM..Mr. Green
Posted: Mon Nov 26, 2007 4:51 pm    Post subject:
So Mike
What was the problem?
Fujifrontier
Posted: Tue Nov 27, 2007 2:24 am    Post subject:
we demand answers
Posted: Tue Nov 27, 2007 10:40 am    Post subject:
He traded up to a Rolls Royce Wink
Heywood Jablome
Posted: Tue Nov 27, 2007 9:33 pm    Post subject:
Rolls Canhardly?
Posted: Tue Nov 27, 2007 9:43 pm    Post subject:
He posted at 5 AM. I think he's sleeping..Smile
