HD 215 THROW DISTANCE
GREG1292
Posted: Tue Nov 06, 2007 1:56 am    Post subject: HD 215 THROW DISTANCE
I am in the middle of my retro conversion lc of a G808s and need to know the throw distance of the 215 lense's. I searched for the link but no luck so far Question
Posted: Tue Nov 06, 2007 2:24 am    Post subject:
It depends on the strength of your throwing arm, your stance, your grip, and how angry you are. Very Happy
But seriously, I thought I had that info handy but apparently that manual is in my storage unit. I believe that the 215 IS covered in
the Marquee user's manual, which is available online as a .pdf file. Search for it.
CJ
GREG1292
Posted: Tue Nov 06, 2007 4:05 am    Post subject:
I chucked the lens 30ft Very Happy Still no luck.
Spotmatic
Posted: Tue Nov 06, 2007 7:20 am    Post subject:
Ask Kal. He has a projector with HD215's installed.
Moose
Posted: Tue Nov 06, 2007 3:25 pm    Post subject:
So does Dave - Person99 - if someone can find out what's happened to him.
Posted: Tue Nov 06, 2007 3:28 pm    Post subject:
See: http://www.curtpalme.com/Zenith1200_Layout1.shtm
Spotmatic
Posted: Tue Nov 06, 2007 3:31 pm    Post subject:
That's why I did not mention him at all. Hope all's well with him!
GREG1292
Posted: Tue Nov 06, 2007 4:41 pm    Post subject:
Thanks Kal I must of missed that. 120 inch screen is 132.5 so I am good shape.
Posted: Tue Nov 06, 2007 4:47 pm    Post subject:
HD215's have really short throw. I mean *really* short. When I changed my BG800 with 8" HD8 lenses for the Zenith 1200 with 8" HD215 lenses on the same 96" wide screen, the projector got installed about 14-20" closer!
Whatever numbers the calculations give you, you'll likely still want to install about 6-7% closer to optimize phosphor usage.
GREG1292
Posted: Tue Nov 06, 2007 6:49 pm    Post subject:
kAL WHAT IS YOUR DISTANCE FROM SCREEN FOR 96"
tHANKS gREG
Posted: Tue Nov 06, 2007 7:05 pm    Post subject:
I don't remember exactly. around 108-110" ? (I'm guessing here).
Don't use someone else's throw: Just set up the PJ, maximize phosphor usage and then move the PJ back and forth until it fits the screen. That's' the correct throw.
I never used the formula's at all.
GREG1292
Posted: Tue Nov 06, 2007 7:47 pm    Post subject:
That is how I do it as well Smile .
Just trying to get an idea.
If my plan works I will hang the retro from the brackets and attached to it to the ceiling.
Throw distance is no problem my slide system allows for 122 to 139 throw distance and my screen will be larger.
Posted: Tue Nov 06, 2007 7:54 pm    Post subject:
Sounds like you're all set!
GREG1292
Posted: Tue Nov 06, 2007 9:45 pm    Post subject:
Just got the retro and the tubes are minty fresh Thumbs Up Thanks Curt
Spotmatic
Posted: Tue Nov 06, 2007 10:22 pm    Post subject:
Psssttt... You suck? Wink Thumbs Up
GREG1292
Posted: Wed Nov 07, 2007 6:20 am    Post subject:
Thanks for the kind words 8) The 215's work perfect on the unit and I have a perfect 10 foot picture. I am going to use the retro chasis as is since I can flush mount in my opening behind me. If anyone knows how to move the red crt up or down please reply.
Spotmatic
Posted: Wed Nov 07, 2007 6:36 am    Post subject:
I don't think the red tube has to be aligned mechanically in the vedrtical direction. There are pots on the vertical board to move the raster up & down. Have a look at Curt's description:
http://www.curtpalme.com/Barco808_Layout3.shtm
GREG1292
Posted: Wed Nov 07, 2007 2:38 pm    Post subject:
Thanks Spotmatic Very Happy I will give that a try. I could be one happy camper. I don't know if it is the lense's or the tubes but focus is razor sharp.
Spotmatic
Posted: Wed Nov 07, 2007 3:30 pm    Post subject:
No thanks! And it's almost certainly the tubes. My former 1208s/2 also had the sharper tubes. No visible scanlines at 1080p, but that resolution was definitely resolved by the projector (almost no overlap). Your projector also has the added benefit of LC, so I envy you with that machine (even though I own a 909).
GREG1292
Posted: Thu Nov 08, 2007 5:15 am    Post subject:
The tip help. This projector rocks. Just need to work on the focus and all will be well Thumbs Up
