Have you tryed this videocard?
Per 489
Posted: Wed Oct 31, 2007 8:58 am    Post subject: Have you tryed this videocard?
Hi
Iīm looking for at graphic or videocard with SDI out to feed my Leeza scaler.
I found this card. http://www.blackmagic-design.com/products/sd/techspecs/ ( the simplest one)
Any experience of this card? Iīm not going to do any videowork, only feed the scaler with a clean signal.
Best regards Per
Posted: Wed Oct 31, 2007 9:20 am    Post subject:
I don't get it. Why would you want an SDI-out computer video card. Usually one goes either the video processor route or the computer route. What display would you use an SDI output with? Please help me understand your intentions.
oliverg
Posted: Wed Oct 31, 2007 10:15 am    Post subject:
There are many that use both the HTPC route in conjunction with the VP too Wink
Per 489
Posted: Wed Oct 31, 2007 10:30 am    Post subject:
Hi
Itīs not the HTPC thing that i really want but there are so few DVD players with SDI out (and very expensive) so i thought of using the computer as DVD player with SDI out
I just found another card http://www.pluggedin.tv/XCard-SDI-Output-module?sc=2&category=2. Any comments on it?
Moose
Posted: Wed Oct 31, 2007 12:33 pm    Post subject:
I doubt if anyone has tried these, but who knows? Why don't you find a card with an HD-SDI output. Probably not cheap but considering that we're moving towards hi-def, it's the way to go in the SDI world.
Posted: Wed Oct 31, 2007 1:31 pm    Post subject:
You mean like this one? http://www.pluggedin.tv/HD-SDI-Modification-Service for 450 pounds sterling.
Per 489
Posted: Wed Oct 31, 2007 2:18 pm    Post subject:
I donīt know if my scaler is built for HD-SDI?
In my opinion itīs not wort it to buy electronic for the future. I only buy what i need to day. Tomorrow is another day.
Strange that nobody has tested SDI to the scaler cause it has to be the purest signal for the scaler to work with. I mean if you have a scaler that costs several thousand dollars you donīt want a simple built-in processor in your DVD to mess around with the signal first.
Best regards Per
oliverg
Posted: Wed Oct 31, 2007 9:05 pm    Post subject:
Per - SDI is great, HDSDI is also but remember that alot of devices are using HDMI which is very comparable.
I bought a Sony BR player from JVB with HDSDIand use it with my Crystalio 2 scaler. It only does a max of 1080P24 (the bandwidth limit for HDSDI) The picture is stunning, but I can't tell the difference between HDSDI and HDMI.
Kind regards
Per 489
Posted: Thu Nov 01, 2007 9:42 am    Post subject:
Ok I undrestand.
Witch model of Sony BR do you have?
Per
oliverg
Posted: Thu Nov 01, 2007 9:53 am    Post subject:
BDPS1 Smile
Its pretty amazing but my PS3 is just as good with its HDMI output.
Cheers
Per 489
Posted: Thu Nov 01, 2007 12:06 pm    Post subject:
HI
I canīt find any HDSDI out on a standard Sony BDPS1 ? Is yours modded? Maybe itīs just called something else?
Specifications:
● Codecs: Blu-Ray, DVD-V, DVD-R, DVD-
RW, DVD-RAM, DD, DTS, MP3, JPEG,
VCD
● Outputs: Composite, S-Video,
Component Video, HDMI. 7.1 Analog
Audio, Toslink, Coaxial Digital
● 480i/480p/720p/1080i/1080p/1080p24
Video (HDMI) 480i, 480p, 720p, 1080i
(Component)
Best regards Per
oliverg
Posted: Thu Nov 01, 2007 12:08 pm    Post subject:
Its modded - I bought it from JVB.
Unfortunately, when regions start becoming an issue I'll only be able to play US BR discs Sad
