Adjusting 2 pole and 4 pole astigmatism magnet
Saeid01
Posted: Mon Oct 22, 2007 4:00 pm    Post subject: Adjusting 2 pole and 4 pole astigmatism magnet
Should I be using low frequency signal 480i or high frequency signal 1080P or I when adjusting the 2 and 4 pole Magnetic adjustment?
Using BG1200
[/b]
Posted: Mon Oct 22, 2007 9:14 pm    Post subject:
Use whatever signal you are going to watch most.
tse
Posted: Mon Oct 22, 2007 9:34 pm    Post subject:
It's always best to do the final adjustments at the resolution that you will be watching. Sometimes the starting adjustments are easier to do at a lower resolution then switch to a higher one for fine tweeking. The 2 pole and 4 pole magnets should be set to a "null" position at the beginning of adjustment. Usually that means set the rings so the tabs overlap. You can verify the null setting by rotating both rings together (either the 2 pole or 4 pole pair) and seeing that not much happens on the screen.
Scott
Thomas Jefferson
Saeid01
Posted: Mon Oct 22, 2007 10:10 pm    Post subject:
I will try it at 1080p and see if I get it any better.
