Manual Gamma Adjustment
Phil Smith
Posted: Sat Oct 20, 2007 6:40 pm    Post subject: Manual Gamma Adjustment
I've searched and I can't find any info on manually adjusting gamma (I don't have the remote option). Can it be adjusted while the PJ is on? Which direction is less and which is more? What position is neutral (no gamma correction)? Any recommendations for the G70?
GEBrown
Posted: Sat Oct 20, 2007 7:08 pm    Post subject:
Phil,
You really didn't try very hard at this one, did you?
http://www.curtpalme.com/forum/viewtopic.php?p=72411
Phil Smith
Posted: Sat Oct 20, 2007 7:13 pm    Post subject:
Gary,
Unfortunately I did try hard. Embarassed
Oh, and thanks for the link!
Phil Smith
Posted: Sat Nov 03, 2007 5:06 pm    Post subject:
I finally got a chance to play around with this a couple of nights ago. As far as I can tell it doesn't work. It's off all the time. No gamma correction whatsoever.
Phil Smith
Posted: Fri Nov 23, 2007 7:33 pm    Post subject:
I e-mailed Moome about this. He said I could change some resistors to increase the gamma boost. He needed to know what version gamma board I had. While checking that out, I removed and installed the gamma board several times to be sure the connector was making good contact. When I reinstalled the card it was working. I'm not sure if it was due to a bad connection that I fixed. To be honest, I was probably doing something wrong. Embarassed
Moome was very helpful and I very much appreciate it. Thumbs Up
Zoyla1
Posted: Fri Apr 03, 2015 10:35 am    Post subject:
Do you know whether Moome is still on track to ship this card out by the end of October 2007? I placed the order for one card last month but have not heard anything yet.
kaleem
