Sony G70 PA Board
AFryia
Posted: Sat Oct 20, 2007 3:13 pm    Post subject: Sony G70 PA Board
Curt,
I was reading Kal's post on your G70 Layout & Setup Tips. I took note that each PA board and PJ are a matched pair.
I'm gearing up for a tube swap and if I'm going through that trouble I'd like to make sure the HV levels are correct.
The HV probe you speak of is that HV probe for an oscilloscope? Assuming one has the tools is the check/adjustment straight forward?
AJF
