BG1208s to LC
Baard
Posted: Fri Oct 19, 2007 7:59 pm    Post subject: BG1208s to LC
Hello
Is it possible to by a Barco Retro G808s chassis and use the parts/lens etc to upgrade my1208s to LC?
Is it worthwhile?
Moose
Posted: Fri Oct 19, 2007 9:01 pm    Post subject:
Sure, it's possible - how clever are you? You'll need a way to support the tube/LC hardware/lens assembly, top and bottom, in the projector. It's not a bolt in. You give up the standard method of mounting these. And you'll need lenses, unless you're happy with a really small screen. LC lenses, that is - the ever popular HD-144/145's are strickly AC. The HD-114-24 and HD-117-24 will work as will HD-215. Good luck trying to find either. I don't what other - or if there are any other - lenses that will fit. Also, I don't know if a retro comes with colored c-elements, so that's a consideration. I'm told that 3M sells them but I have no idea how to contact them.
People have done this. I have the parts to do it to my 808, including HD-215 lenses and colored c-elements, but I don't know if I really want to right now as I have begun a speaker project that will eat up my time and money. So I'm thinking of selling.
Barco did make a few LC 1208's. They're awfully rare though.
lucht
Posted: Fri Oct 19, 2007 10:39 pm    Post subject:
There are also the HD214 which Barco has used for Retro's, which have also as the HD215 no corner focus adjustment on the lens. The HD117 have a corner focus adjustment on the lens.
I am personal interested what the c-element mid-depth is original for a HD215 lens to the mountinglevel of the lens, because for a HD117 is these 36 mm and for a HD214 45 mm.
Moose
Posted: Sat Oct 20, 2007 3:07 am    Post subject:
All I know is that the c-element in the HD-117 that came with my LC hardware and the c-element's I have that came out of a Sony G70 appear to be identical. I guess I don't quite understand what you mean by mid-depth.
lucht
Posted: Sun Oct 21, 2007 8:50 pm    Post subject:
[quote="Moose"]
If you put a liniaal cross-over from one mounting point of the lens to the other on the LC housing and measuring the dept in the mid to the c-element
