Barco reality 909
gerom
Posted: Sun Oct 14, 2007 8:28 am    Post subject: Barco reality 909
Hi, Very Happy
I have br909 problems, all remote control are locked, and there is only one internal block. I can only control my 909 with "barcoexplorer" program.
1- do you know how to do for unlock it?, Barco explain that it is possible to do it with rs232 comunication protocol, but I have not barco software to do it.
2- can somebody send me file copy from all blocks of one BR909 ?
3- is there somebody who succeed in doing barco eprom upgrade Question
Best regards
Thierry
Spotmatic
Posted: Sun Oct 14, 2007 10:56 am    Post subject:
You should ask Mike Parker. He's also experienced with these beasts!
Posted: Sun Oct 14, 2007 12:03 pm    Post subject:
Delete all blocks and start from scratch . Also read this...
http://www.crtprojectors.co.uk/barco_faq.htm#Q:%20My%20Barco%20remote%20has%20stopped%20working,%20what%20has%20happened?
Mad Mr H
Posted: Tue Oct 16, 2007 10:21 pm    Post subject:
909 / Cine9 eprom upgrade is NOT the same as all other digital chassis Barcos.
There are only a couple of people I know able to do 909 / Cine9 eprom upgrades and NONE of those are available to "joe public".
the 909 does NOT use an eprom swop.
1209s and below are able to have new eproms installed in place of the old one.
Each block is created when a new signal style is sent to the PJ.
Remote issue - have you set the remote to talk to the PJ - often the remote is not set to control the PJ.
You need to set the PJ ID and the remote ID to be the same.
boomtruckman2003
Posted: Tue Oct 16, 2007 11:56 pm    Post subject:
i have a barco remote part number R763604 for a slm elm series projector,
does anyone know if this can this be programmed to work on a 1209s?
thanks
Spotmatic
Posted: Wed Oct 17, 2007 5:16 am    Post subject:
thanks
Although this is offtopic: yes, the remote will also work on a 1209s. If it does not seem to work, press the recessed button with a Pencil. The 1209s should then display its address on screen. If it is 0, press QUICKLY 0 on the remote. It should then work like it should...
Posted: Wed Oct 17, 2007 9:02 am    Post subject:
If the wired control (remote attached to the set) will not turn the set on, the problem is not settings.
The wired control will not operate if certain things are not on par in the projector. RS232 control should allow you to look at the voltage/diagnostic menu and see what readings are in there.
There are two different version of the G2/Diagnostic board. Shoot me a PM with the part number on the diagnostic board along with the diagnostic readings.
Firmware upgrades and IR settings are not related to this problem.
gerom
Posted: Wed Oct 17, 2007 5:38 pm    Post subject:
Problem solved, Very Happy
it was a lock of IR, not need Barco programs, we need direct access to RS232, and then send the protocol Barco adapted to the machine.
But others problems see: Confused
http://www.cinetson.org/phpBB2/viewtopic.php?t=23689
Regards Wink
Thierry
Posted: Thu Oct 18, 2007 1:53 am    Post subject:
If that was a normal projector I'd say the Video Output amplifier is blown, on blue at least. But the 909 doesn't run a standard off the shelf Video Output Amplifier chip.
boomtruckman2003
Posted: Thu Oct 18, 2007 2:20 pm    Post subject:
sorry for cutting in on this thread, but i thought you guys would know,
but i still cannot get the remote to work, thanks
gerom
Posted: Thu Oct 18, 2007 4:00 pm    Post subject:
Sorry, but I doesn't understand your question.
I'm french and my english is poor. Embarassed
n@t
Posted: Mon Nov 05, 2007 9:10 pm    Post subject:
it was a lock of IR...........
Thierry
Which command?
Dat1 = 7FH <<< ???
Regards
Bernd
think positiv
n@t
Posted: Wed Nov 07, 2007 8:09 am    Post subject:
Thierry
I also 8)
I show the solution without the money it costs.
Je pense 150 €, ce n'est pas de demander raisonnablement Thierry.
You need eventghost.
Add serial plugin
new makro
Serial / Write Add
\x02\x00\x00\x50\x7f\x00\x00\x00\xcf register as described
and to execute press
Thats all......
Regards
Bernd
think positiv
gerom
Posted: Sat Nov 10, 2007 4:14 pm    Post subject:
n@t wrote:
Thierry
I also 8)
Add serial plugin
new makro
Serial / Write Add
Thats all......
Regards
Bernd
Hello, Josef.
Do not be bad player Josef Wink
I had bought to you barco 808s Convergence part for 117 euros.
This card was little failure, I had to send it into the technical-station for adjustment. Crying or Very sad
Recently you contacted me to repair a BR909 controller, I have proposed to repair it for 100 euros and not 150, with a payment only after repair.
This is a proposal and not an obligation.
I am open to the dialog and always ready to render service.
Regards
Thierry
