bbfarmht
Joined: 27 May 2006 Posts: 1273 Location: Where the Mississippi runs east to west!!
| Posted: Sat Oct 13, 2007 1:21 am Post subject: lc bg 808s? |
i was wondering if anybody could shed some light on doing a lc bg 808s conversion. I have the p16lnp tubes with the lc housings and i am thinking about trying to do this conversion. I have seen posts before about doing this but everybody gets sidetracked from the actual subject.
Z-Photo
Joined: 07 Mar 2006 Posts: 2749 Location: Huntsville - Alabama
| Posted: Sat Oct 13, 2007 1:40 am Post subject: |
Here is the link to the very first post on Curt's Forum
The BARKENSTEIN - (or how to convert a retro BG 808s to a FP BG808s with mec tubes)
https://www.curtpalme.com/forum_archived/viewtopic.php@t=6.html
_________________ Engineer by Day
Photographer by Night
My Portfolio
bbfarmht
| Posted: Sat Oct 13, 2007 2:11 am Post subject: |
Z was this a s model ? also what lenses did you use i was thinking of using hd 145 but Im not sure what would be compatible? how different is the ac mounting from the lc mounting?
| Posted: Sat Oct 13, 2007 2:42 am Post subject: |
bbfarmht,
You can't use the HD-145 lenses with an LC conversion as they are AC lenses, however if you do get the 145's you will get improved focus, better colors, and possibly reduction in halo's
Erik
bbfarmht
| Posted: Sat Oct 13, 2007 3:09 am Post subject: |
Zebu,
thanx but that still leaves me wondering what lenses to use and the other thing that I am not sure about is the way its mounted to the projector I keep reading that the lc mounts are in halves! if they are i would like to know what they look like so i can go to the cnc and try to make mounts to work..
When the wife gets you down trade her for a barco!!!!!
Can you really make money off of ponies???
Adam
joerg
| Posted: Sat Oct 13, 2007 7:54 am Post subject: |
HI,
I have a retro BG808s and I use HD117-24 they work perfectly the throwing distance is ca. 60cm shorter then HD8s(Screen width 2m).
You can not use the hd215 of an Zenith1200 I tryed it and it is not working.
See here
https://www.curtpalme.com/forum_archived/viewtopic.php@t=4242.html
Joerg
_________________ My Girlfriend thinks size matters and she is right!
Owner of the uglyest Barco 808sLC
