| Posted: Fri Oct 12, 2007 2:30 am Post subject: One for the torus guy's |
I'm considering building one for the setup I have in the garage. (which is no longer a garage but a work-shop) Is there a formula for choosing the radius of the screen. Also, when considering radius, where do you place the point of origin of the radius. I'm working on a way to build a accurate mold to form one out of fiberglass 8)
_________________ Chip
Z-Photo
Joined: 07 Mar 2006 Posts: 2749 Location: Huntsville - Alabama
| Posted: Fri Oct 12, 2007 2:45 am Post subject: |
Cool
A cross-eyed Ampro
Thats a new one.......
_________________ Engineer by Day
Photographer by Night
My Portfolio
-Pjackso
| Posted: Fri Oct 12, 2007 4:14 am Post subject: |
Chip,
Here's a spreadsheet I developed quite some time back to calculate a mathematically accurate torus. It outputs the top/bottom/side torus profile dimensions. It'll also calculate the overall torus radius (F).
I put the torus focal point at the viewer.
Hope it helps.
| Description: |
 Download |
| Filename: |
Torus calculator explained v2.xls |
| Filesize: |
104.5 KB |
| Downloaded: |
267 Time(s) |
_________________ -Nothing relevant to add.
| Posted: Fri Oct 12, 2007 5:02 am Post subject: |
How would you 'hollow out' your screen material? Or would you just bend plywood to match those curves?
Is this screen good for more than one viewer? When I plugged my numbers in it seems like a very small viewing cone. Maximum Torus Depth was 41.41" wild.
