Barco 808 g displays only upper half of image
jaredjaric
Posted: Sat Oct 06, 2007 10:32 am    Post subject: Barco 808 g displays only upper half of image
just bought an 808g,the tubes are burn free,but the video has some static or flickering and displays only upper half of the video.Please help before i do something to wrong. Embarassed
jaredjaric
Posted: Sat Oct 06, 2007 10:36 am    Post subject: Barco 808 g displays only upper half of image
also on the crt face ,you can clearly see the image cut in half,as if the blanking was covering it.
Posted: Sat Oct 06, 2007 12:44 pm    Post subject:
It sounds like the V board is bad, and I would not use the set that way.
Can you post a pix of the test grid? (turn down the brightness and contrast to very low, and set the exposure time to high.)
jaredjaric
Posted: Sat Oct 06, 2007 1:03 pm    Post subject:
right now it is only the middle half image.i will post a pic of it asap.Thanks
jaredjaric
Posted: Sat Oct 06, 2007 2:18 pm    Post subject:
here are the pix
 Filesize:  43.7 KB
 Viewed:  5986 Time(s)
jaredjaric
Posted: Sat Oct 06, 2007 2:20 pm    Post subject:
no. 2 pic
 Filesize:  42.81 KB
 Viewed:  5984 Time(s)
Posted: Sun Oct 07, 2007 12:40 am    Post subject:
OK, it's not V deflection failure, it's something to do with the blanking. I'd say V board or controller module issues. If you want, let me know, and you can send them to me for testing.
Posted: Sun Oct 07, 2007 12:20 pm    Post subject:
Try deleting all blocks then try centering the rasters in the setup menu.
jaredjaric
Posted: Sun Oct 07, 2007 2:07 pm    Post subject:
thanks Curt ,Tom.will try to check the v board.Smile
jaredjaric
Posted: Sun Oct 07, 2007 3:31 pm    Post subject: vertical amplitude too tall
Here is a new pic after deleting all blocks and setting everything to midpoint.That is what i got ,still a stuttering image but
looks like the vertical adj.was set too high.Help ,Does anyone think that is the case?the trimpots are in the V board ,is it not?
 Filesize:  80.58 KB
 Viewed:  5901 Time(s)
Posted: Sun Oct 07, 2007 4:52 pm    Post subject:
Read this and check out the SMPS solder connections.
http://www.curtpalme.com/Barco808_Layout6.shtm
jaredjaric
Posted: Mon Oct 08, 2007 5:58 am    Post subject:
Thanks,will check the smps solder.
Posted: Mon Oct 08, 2007 2:31 pm    Post subject:
Do resolder the SMPS regardless, but this is most likely an internal V board issue. That's also where the V sync takes place.
jaredjaric
Posted: Tue Oct 09, 2007 1:44 am    Post subject:
the two trimmers onthe board,are almost not affecting the red and blue v amplitude.Probably some misadjustments in the whole v/sync board
