Sony VPH 1271 with unsteady shaking picture
CRTVoyager
Posted: Fri Oct 05, 2007 11:29 pm    Post subject: Sony VPH 1271 with unsteady shaking picture
Hallo friends and experts of the CRT club,
since 2005 I own a used 1271 with low hours, good tubes, a DVI input board and now with a big problem.
After setting the Sony up I had a good time watching movies for a while.
A while later my CRT started to show shaking lines inbetween a movie. Not the whole screen yet.
Then the shaking got worse and stayed longer.
When I was really lucky I sometimes had days when it didn't occur, but the next time it would start again.
Going along with Curt's advice I removed all the boards and remounted them and checked on every connector I could see.
Unfortunately with no effect. The picture is shaking all over and it is the same with the test patterns. So I can clearly exclude any failures concerning the sources ( DVD Player, DVD's, cable ).
So does anyone in this forum know what else I can do to get my baby working properly again.
Is there any special board inside that might need to be replaced?
Any help is appreciated.
Greetings Joe Crying or Very sad
Brooklyn
Posted: Sat Oct 06, 2007 8:13 am    Post subject:
I have had a similar problem. I replaced the DC and E board in my 1270, and it seemed to fix the problem.
CRTVoyager
Posted: Sat Oct 06, 2007 5:35 pm    Post subject:
Hallo Brooklyn,
glad that I got at least one good hint to what might by the cause of this shaking effect. How did you experience this effect on your 1270 and who gave you the idea to change especially these two boards?
I'll try to get hold of these two boards. I'll start a request on the forum right away.
Thank you again for answering
Greetings Joe
tony359
Posted: Sat Oct 06, 2007 8:31 pm    Post subject:
Had something similar, was the DA board (sync).
Do you have it with any signal, test patterns, input...
Ciao
A
CRTVoyager
Posted: Sat Oct 06, 2007 9:14 pm    Post subject:
Hallo tony359
well actually yes. It doesn't matter if I have my DVD player connected via DVI input or if everything is unplugged from the CRT and I run the test patterns. The shaking of the picture is permanent now and it appears with the lines shaking fast from left to right an vis versa. Unfortunately after my action reseating the boards it seems that it has worsened the situation.
Bye Joe
tony359
Posted: Sat Oct 06, 2007 9:27 pm    Post subject:
If the situation has worsened, perhaps you have something loose in one card, Curt can repair or replace for you...
CRTVoyager
Posted: Sat Oct 06, 2007 9:59 pm    Post subject:
When it comes to spare parts I guess I will end up with Curt anyway as he certainly has the biggest collection of parts anywhere.
imprez25
Posted: Mon Oct 08, 2007 2:16 am    Post subject:
I had the same issue with a 1251, I replaced the DA (Sync) Board and the picture looks great now.
