This install is the shiznit! (find the G90!)
Posted: Mon Oct 01, 2007 3:57 am    Post subject: This install is the shiznit! (find the G90!)
So I go to this house in Seattle today to connect an HDFury, etc and do a setup to this G90 that was installed in 2001. First off, props go to Definitive Audio, one of the high end audio installation companies in the Seattle area. I've dealt with them before, nice buncha guys.
So, I go into the room, the installer is talking to the customer in the other room. I start looking for the projector... the room is nicely laid out and VERY dead acoustically, thanks to the sound absorbing panels on the ceiling and walls, and the thick carpet at my feet. Comfy! Thumbs Up
So I look at the ceiling, no projector. I look at the coffee table that's wide open, no projector hiding there. The Stewart screen material is very white, so I'm thinking it's a FP setup. THen I'm thinking that I'm possibly in the wrong room, maybe there's a digital poking out of the soffit at the rear? Nope. I'm doing the 'WTF' head scratching, but then I notice a door open to the left of the 52 X 92 screen. Here's what I saw:
First, there's the RP Stewart screen.
 Filesize:  213.63 KB
 Viewed:  7214 Time(s)
I see this big ass optical grade mirror, aha, so it's a RP setup, but wait, the screen is pointing towards the CEILING!!.....
 Filesize:  277.99 KB
Finally, the projector is about 10' up in the ceiling, firing down at as steep of an angle as this pix looks like. How the heck did Definitive get this projector in it's metal cradle and aim it without dropping it???
 Filesize:  416.03 KB
Posted: Mon Oct 01, 2007 4:05 am    Post subject:
Audio-wise (looks a bit messy, it's being worked on), the MAP rack is a model that I haven't installed in a long time: It's got rails that sit on the floor (removable) so you can slide out the whole rack to work on it. Slide the rack into place, remove the rails, it all tucks into the wall unit.
THere are 2 pairs of Revel speakers for the surrounds, one pair on the rear ceiling, one pair built into the columns.
Two Servodrive subs (these kick ass!) powered by a Mark Levinson 150 lb amp that sits under the screen.
Note: 14 and 12 gauge PVC jacketed cable, none of this esoteric cable garbage..Wink
 Filesize:  121.38 KB
 Viewed:  7209 Time(s)
 Filesize:  174.52 KB
 Filesize:  353.49 KB
Posted: Mon Oct 01, 2007 4:06 am    Post subject:
Hehe
God help the next poor SOB who has to crawl up there and try to fix anything on the 90.........
Posted: Mon Oct 01, 2007 4:28 am    Post subject:
Wouldn't that be Curt? Wink
Nice install, that's what I look for in a rear projection TV. Very Happy
Posted: Mon Oct 01, 2007 4:56 am    Post subject:
The attic is fully open. I believe there's a quick release on the bracket to instantly crush would be burglars..Wink
Posted: Mon Oct 01, 2007 9:15 am    Post subject:
Wait a second ... this thing is hanging down from the attic? Now that's an interesting way of doing things! I wonder how he is keeping it cooled in the midst of Summer. Is the attic finished?
Posted: Mon Oct 01, 2007 12:49 pm    Post subject:
Did you LOOK at the pictures? Wink
I don't know, I didn't go into the attic.
Dave Lister
Posted: Mon Oct 01, 2007 1:46 pm    Post subject:
Oriented like that no smeg can fall into the guns of the CRT's and cause a short of the guns or heater filament.
Stuff for sale;
Posted: Mon Oct 01, 2007 1:56 pm    Post subject:
What kind of picture did it produce???
What did it look like?
and to dave......smeg????? Confused
Posted: Mon Oct 01, 2007 2:07 pm    Post subject:
It was killer. The only strange thing is that the main clock showed 11700 hours on it, the tube counter showed 1700. No idea where the extra 10K chassis hours came from! Scan lines at 8' at 1080i? Man oh man...Smile
Also, we connected the component 1080i out through the Denon receiver to the projector, then used a second RGB line using the HDMI out to the Sony as well at 1080i via the Fury. We saw no real difference in performance between the two. There was some color shift, but since there were two different memories used in the Sony, I didn't spend a lot of time setting both up to be identical. Once the BR player comes in and the Denon HDMI issue gets resolved we'll go HDMI all the way.
Phil Smith
Posted: Mon Oct 01, 2007 5:25 pm    Post subject:
Very cool setup! I'm surprised by the white screen though. I experimented with a white shower curtain. It looked good, but light reflecting off of it REALLY lit up the projection room. Some of the reflected light bounced back onto the screen and ruined the black level of the picture. I think you would need the entire projection room to be black to have good results with a white screen.
The other problem was it was no better than a FP white screen in ambient light. Good ambient light performance is one of the biggest benefits to RP (at least in my mind). A gray screen accomplishes that (that's why all RPTVs have gray screens). And gray screens seem to make colors really saturate for some reason (maybe because of better blacks).
Anyway, that's a NICE setup!
KnottyMan
Posted: Mon Oct 01, 2007 8:59 pm    Post subject:
emdawgz1: google Red Dwarf. Dave Lister is the main character. Very British show and very funny if you like that kinda stuff.
smeg ~ "bad stuff"
jantje112
Posted: Tue Oct 02, 2007 2:26 pm    Post subject:
I't looks like there some text on the screen? Is that a refelction of something?
Posted: Tue Oct 02, 2007 3:13 pm    Post subject:
That would be the football game that was running when I took the pix. Seahawks won! Smile
