HD-144/145 lens
philm
Posted: Sun Sep 30, 2007 3:39 pm    Post subject: HD-144/145 lens
Hi guys, have any Sony owners changed out the HD-8 lens on the 12x with the 144/145's or would it be of any gain worthwhile? What kind of adapters would be needed?
Thanks.
Posted: Sun Sep 30, 2007 3:41 pm    Post subject:
I'm not sure if adapters are avalable, but you could try to find a set of pt-65 lenses that should have better focus than the HD-8'S
Erik
Posted: Sun Sep 30, 2007 3:43 pm    Post subject:
Yes it can be done. You need a set of lenses and Joust adaptors. They are available on this site from the front page link.
http://www.curtpalme.com/JoustModsAdapters.shtm
We talked about doing this but none of us ever did. I scored a mint set of PT-65 lenses and called it a day. Why not give it a try? You can always reuse the adaptors and lenses when you upgrade to another 8" AC projector latter on.
Also check out these posts:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=5019.html
https://www.curtpalme.com/forum_archived/viewtopic.php@t=3817.html
Posted: Sun Sep 30, 2007 4:01 pm    Post subject:
Oh I forgot to mention. You'll need the clear lenses as your projector already has the tinted glycol.
Posted: Sun Sep 30, 2007 10:43 pm    Post subject:
I didn't see enough additional sharpness with my M8500 to make it worth the hassle and expense of HD145's. I kept the lenses because of the color filtering, not the focus improvement. If my projector already had tinted glycol, I wouldn't bother with HD145's. But that's me.
philm
Posted: Sun Sep 30, 2007 11:19 pm    Post subject: HD-144/145 lens
Thanks again guys for all your valuable input, I'll report later if i go this way.
Phi Smile
Joust
TV/Projector: Marquee 8501LC
Posted: Mon Oct 01, 2007 12:47 am    Post subject:
If the sony uses or can use standard HD8s then my adapters should work in it.
www.joustmods.com
I'd be very interested in seeing your results.
