Looking for Pin Config for XG135LC (Option to PC Serial)
NEChelpNEC
Posted: Fri Sep 28, 2007 7:18 pm    Post subject: Looking for Pin Config for XG135LC (Option to PC Serial)
Question Hi.. I am trying to hook up my PC using the Pc Control Software to my XG135LC (and XG110LC). On the back of the XG there is a 15pin "Option terminal" (looks like pc rgb) which needs to hook up to a 9-pin Serial Com port on the PC. The PC Control Software does not show you the Pin configuration and the XG Maunals only show you the pin configuration for the 15-pin "Remote terminal". Anyone have the pin out for doing this?..thanks alot. Ed Shocked
dbaisey
Posted: Fri Sep 28, 2007 7:39 pm    Post subject:
http://www.curtpalme.com/NECXG_PCControl.shtm
Note that the 9 pin shows female. Doug
NEChelpNEC
Posted: Fri Sep 28, 2007 9:44 pm    Post subject: Thanks Doug
Thanks Doug..I'll give it a shot Thumbs Up
dbaisey
Posted: Fri Sep 28, 2007 9:49 pm    Post subject:
If you look real close the back of the 9 pin female will be numbered as well as the 15 pin male. No other pins can be terminated together so check those if using something already made up on one end. Doug
