barco trouble
kbgreen
Posted: Sun Sep 23, 2007 12:21 am    Post subject: barco trouble
Hi
I sat down to watch a movie and turned on projector and can't seem to get it out of standby mode,this is a Barco 1208/2
the standby light is on {red} on back panel near power switch.I put a new battery in remote and it seems to be OK,lights on remote work when buttons are pressed.
Any ideas are welcome.
thanks
kbgreen
gonyr
Posted: Sun Sep 23, 2007 1:47 am    Post subject:
If the projector works with the wired control panel, it's probably the remote. Try setting the remote address - press the recessed address button, then zero. This should solve the problem. I had to do this after replacing my batteries.
scotha
Posted: Sun Sep 23, 2007 2:05 am    Post subject:
My bd 808s has done the same thing if the power cuts off and back on. I had to unplug the set for several hours then it was fine.
pj. BD808s, BD801s
Ile
Posted: Sun Sep 23, 2007 1:42 pm    Post subject:
If internal remote won't get it running, you have problems probably in smps.
Check F100 fuse from smps main board, it's that one with screw top casing.
kbgreen
Posted: Sun Sep 23, 2007 9:02 pm    Post subject:
thank you all
i reset the remote and it works fine now,thanks again.
kbgreen
