vga->vga vs vga->rgbhv breakout
snkby
Posted: Thu Sep 20, 2007 3:22 am    Post subject: vga->vga vs vga->rgbhv breakout
just wondering what thoughts are on this topic.
i currently have 1' vga breakout to 25'silver-plated copper rg-6 compression-terminated in bnc for rgbhv input to marquee8000.
im wondering if :
1) 25' vga cable to 1' breakout rgbhv cable at pj might be better ?
2) 25' vga cable to vga input at pj would be better ?
i just installed a 10m nice quality vga cable between a mac-mini and an elite 60" and the pq wrt sharpness and lack of noise/artifacts was pretty impressive.
i would have tried it on my rig before installing it for the customer except that i had it shipped to them directly. Sad
thanks.
jask
Posted: Thu Sep 20, 2007 3:38 am    Post subject:
with a good vga it is probably a non issue at that length,but the rg-6 is a better signal path.
Posted: Thu Sep 20, 2007 9:07 am    Post subject:
Why separate the five signals for a mere foot? If you are considering the consequences of the last-foot then you are really more concerned with the physical interface at the projector, no?
On the other hand, if you are concern with the r, g, b, h, and v in proximity to one another I would think that finding the shorted breakout cable and making five RG-6 cables for the remaining 24' would be in order. You could also use premade cable and just find the necessary adapters for the ends:
Pre-made 25' RG-6 cable:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10235&cs_id=1023501&p_id=2857&seq=1&format=2
RCA-to-BNC adapter:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=090-400
Or, you could just get someone to make you a customer cable (like I did).
GEBrown
Posted: Thu Sep 20, 2007 12:39 pm    Post subject:
BlueJeansCable.com recommends a short breakout cable and longer runs of RG-6 above 17ft (IIRC). I don't have the tools to measure the difference, so I take their word for it.
I guess the real test is your eyes - set up both and if you can see a difference, then there is one, otherwise there is no difference.
Posted: Fri Sep 21, 2007 9:20 am    Post subject:
Of course you could go all nutso and have someone (MP?) modify your HPTC's video card for 5xBNC output, too. Smile
