Barco G808 scan fail light on G2/diag board
ElTopo
Posted: Mon Sep 17, 2007 9:21 pm    Post subject: Barco G808 scan fail light on G2/diag board
Hi all,
my SMPS was repaired and i checked the projector today.
Did a setup from scratch and saw that the blue raster was way to down compared to the green.
So i tweaked the blue master V shift pot on the vertical board to adjust the blue.
Works fine so far and setup was finished.
I watched a movie and after about 30 min i got the red light on the G2/diag board and the tubes go off.
After putting the projector to standby and back on everything works fine for a couple of minutes and the the same prob, red light on.....
So what do you think is the problem ?
SMPS once again ?
V board ?
H board ?
thx for input
ElTopo
ElTopo
Posted: Tue Sep 18, 2007 6:20 am    Post subject:
Also the red led on the vertical board lits up!
Which board should i replace first ? Or should i try any other troubleshooting ?
thx
