Per 489
Joined: 09 Jun 2007 Posts: 31 Location: Aaland. Finland
| Posted: Mon Sep 10, 2007 7:13 am Post subject: EM 8500LC + Leeza no picture? |
Hi
Just bought a EM 8500LC and a Leeza scaler. To this I got a RGB +H videocable (4xBNC) 25 feet long with Canares BNC.
I canīt get a picture. It says "out of Vertical scan rate"
The guy I bougt it from think the signal is to weak and is going to send me an amplifier but I honestly dont need (want) to have another device in my system.
Anyone having any other idea?
Im going to try a shorter complet RGBHV cable. Is VGA an option?
Best regards Per
Joust
TV/Projector: Marquee 8501LC
| Posted: Mon Sep 10, 2007 3:07 pm Post subject: |
test 8500 with another source. (pc works well)
if problem persists on the PJ, pull CLM and press all chips then try it again.
kschmit2
| Posted: Mon Sep 10, 2007 3:52 pm Post subject: |
are you trying to feed it a 1080p24 signal?
If so, it won't be able to sync to that.
Try 1080p48 instead.
Per 489
| Posted: Mon Sep 10, 2007 4:47 pm Post subject: |
Hi
I can get a picture from DVD by S-video input in the projector but not from the scaler (I did take it down to 480P) by RGB +H.
Next thing I will try is to go by VGA (it does say RGB on the projector) I just haveīt had time to dig one up yet.
Best regards Per
Joust
| Posted: Mon Sep 10, 2007 5:28 pm Post subject: |
thats the next step.
tune your PC output to the same res that you want to display and see if that works.
AFAIK the 4 BNC input should work. you may end up having to make a ckt to split out H and V sync from the composite sync input. thats a simple exclusive OR gate setup.
