fuzzybee
| Posted: Sat Sep 08, 2007 8:14 pm Post subject: Anyone here controlling a ISS Switcher via serial? |
I can't seem to get the switching commands working correctly. I have the switcher turning on and off fine. When I try to switch to a particular input, I see the number pop up on the display, but it never switches. The switcher also locks up. Here's the string I'm using to switch to input 4:
| Code: | | \xBF\x20\x13\x00\xF2 |
Is that the correct string?
fuzzybee
| Posted: Sat Sep 08, 2007 9:28 pm Post subject: |
Also, does anybody here have a description of what the control card dip switches do?
fuzzybee
| Posted: Sun Sep 09, 2007 2:51 pm Post subject: |
Argh. It appears that mine is also not responding with it's ACK responses. I can still power on/off, but there is no response. I have a feeling this is tied to those dang dip switches!
jask
fuzzybee
| Posted: Thu Sep 20, 2007 12:08 pm Post subject: |
Yeah, that's the same manual that Curt has here. It looks like my control board has decided to not respond to my commands. I have another one sitting at the post office waiting for me to pick it up.
jask
| Posted: Sat Sep 22, 2007 7:35 pm Post subject: |
all right then.....
two things
1 is your projector in the sw1 level mode in the menu? ( adjust>option>setting mode>connect condition> sw1 level)
2 are the dips in the ISS all closed except for #8.... (all down with #8 up) this is the only dip setting you will need unless you plan to daisychain several switchers
otherwise I would try a new cable
