grogthegreat
Joined: 16 May 2007 Posts: 166 Location: San Diego, CA
| Posted: Thu Aug 30, 2007 6:39 am Post subject: 9PG+ flickering only at 720p from PS3! |
I have a 9PG+ for a couple of months now and it has been working fine until recently. When I hooked up my friend's PS3 to the projector it has a weird flicker affect. There are several strips of horizontal white dots that dance randomly on the screen sometimes pulling parts of the picture near the dots temporarily sidewise for a split second. This only happens at 720p. 480i, 1080i, even 1080p are all perfect from the PS3. My xbox360 and HTPC, both at 1014x768 are fine. My signal path from the PS3 to the pj is HDMI to HDFury to F-F VGA gender changer to a 10' breakout cable. I have swapped the breakout cable and it didn't solve anything. I also noticed that the issue doesn't start untill the projector fully warms up (about 15 minutes). This is even if the PS3 and HDFury are both warmed up beforehand. Also when it happens the projector isn't showing an error code on the back.
So here is the obvious question: What is wrong and how do I fix it? Thanks in advance,
Greg
_________________ First projector: Sony 1252q with 3500 hours
Second projector: NEC 9PG+
current projector: Sony G90
100" 3:4 draper screen.
I must keep upgrading till the voices stop!!
"I CAN HAZ CRT PRUJEKTER."
-Curt Palme
