G70 HV Problem (Back Again After a Year)
Posted: Sat Aug 25, 2007 2:26 pm    Post subject: G70 HV Problem (Back Again After a Year)
This is with the G70 that I recentally picked up.
The projector was working fine last night but now when I power it up I get error code 33 and the projector shuts down. It said in the manual that this is a HV errror.
I unplugged the HVPS from the splitter and capped the ends of the lines and it powered up fine w/o any errors. I also ga sort of hissing from the splitter. Does this sound like a HV leak
Erik Sad
Posted: Sat Aug 25, 2007 4:33 pm    Post subject:
I think you have a tube that's shorted or a CRT socket that's overloading the HV. I'd connect the red tube back up via the HV lead and see if it works. HTen the green, then the blue. I have not had a 33 error code here before. It could mean your PA board is bad though.
Posted: Sat Aug 25, 2007 4:56 pm    Post subject:
Thanks Curt,
Poking around this morning I uncovered the problem, The HV line that runs from the HVPS to the splitter was loose on the PS end and the connections on the tubes to the splitter was not the best. Reconnected all and it lives again.
Erik
oliverg
Posted: Sun Aug 26, 2007 2:27 pm    Post subject:
Man you must be SO happy that you found the problem!!
Posted: Sun Aug 26, 2007 2:29 pm    Post subject:
Yeah I am,
All seems to be well now the projector just ran for eight hours without any problems whatsoever.
Posted: Sat Aug 02, 2008 4:18 pm    Post subject:
This problem has returned. I went back and tightened up the connections at the splitter and all was well again. I'm curious if any other G70 owner has seen this problem?
Luckly the problem is easy to fix but I don't like the feeling of loose HV in my G70 zapping boards. Has anyone had a splitter go bad?
Posted: Sat Aug 02, 2008 6:29 pm    Post subject:
Glue it into place. ???
Posted: Sat Aug 02, 2008 8:52 pm    Post subject:
how do yuo "tighten up" the splitter connections. these are simply twist-lock arrangements. They either twist lock in or they don't.
I'm going to guess a crack on the splitter. If I remember correctly the upper portion of the terminal block is Glass?
doubleuf
Posted: Thu Jan 22, 2009 1:17 pm    Post subject: I have this same symptom, eror code 33
Hi Zebu, I have exact the same symptom. My G70 worked last night and now it only gives me the error 33 when I power it on.
You mentioned in your post HV line, the HVPS and the spliiter, I appreciate if you could guide me as where can I find them in the G70.
Many Thanks.
WF
doubleuf
Posted: Thu Jan 22, 2009 3:06 pm    Post subject:
I manage to find the High Voltage DC block and there is a HV line connected to the High Voltage DC Block (4 lines) I think this is the splitter, I check all four HV cables and they look pretty secure. But they erorr 33 is still there! Sad Any suggestions are appreciated.
WF
Posted: Thu Jan 22, 2009 3:37 pm    Post subject:
I've never had a G70 HV block fail, but there's always a first time.
I also have not had a 33 error code, but the Pa board controls the HV, so that's where your problem might be.
FYI, the Sony error codes are not always correct. I repaired a G90 in Whistler, BC yesterday that would shut down intermittently. It pulsed in an H direction, then would shut down. Came up with an H stop error code. Swapped the H board, nothing. Swapped the CPU and video input boards, nothing. Swapped the power supply and that was it.
I'd suspect the HV splitter pack or the PA board in this case though. I can test them here if you want.
Posted: Thu Jan 22, 2009 5:28 pm    Post subject:
When I was getting the error, seems to happen about once a year I always fixed it by pulling the HV lines out of the splitter and pushing them back in HARD. Sometimes I would have to reconnect the lines a few times before the error would go away.
Good luck fixing it.
Erik
Posted: Thu Jan 22, 2009 6:39 pm    Post subject:
Sounds like you have a different problem. I've worked on 100s of Sonys, and have never had that problem. I'll bet the flexing of the leads shifted something else in the set to get it to temporarily cure itself.
Posted: Thu Jan 22, 2009 8:29 pm    Post subject:
Curt, which power supply board did you change that fixed the problem? And are you calling the ED board the "H board"?
Posted: Fri Jan 23, 2009 4:21 am    Post subject:
I'd have to look at the set still in my truck for board numbers, not up to speed with the various G90 board #s.
I changed the main LVPS that drives most of the set. THe set would usually power up, but with no video or menus, just a dimply lit blank screen. You'd see the raster pulse width-wise, the n eventually it would collapse and the set would shut down well before the raster would collapse into a line. Strange how well protected the set was up in Whistler, but I now know of two sets that had raster collapse with a phosphor burn on each tube.
The H board that I changed first that's fine is the one that the blue and red yoke wires go to, the H output board. It was OK.
I was also called on this set for a small H whining sound, that I attributed to a singing transformer in the H or power supply section. THey called 2 years ago, but opted to live with it since I had no spare G90 parts at the time. Since I did the SMPS and H board swap, I didn't hear any singing from the set, so I think I cured that as well.
THe tab for 3 hours on site and travel and parts was $1500, and they didn't have to pull the set down. I'd guess the bill would have been double or triple that if they would have had to send it to Sony in California.
doubleuf
Posted: Fri Jan 23, 2009 4:55 am    Post subject:
Thanks, Curt, do you mean to take out the HV splitter and the PA board and send them to you?
May be I should first take it down from the ceiling! Sad
WF
Posted: Fri Jan 23, 2009 5:26 am    Post subject:
They should come out without having to take the set off the ceiling. THe PA board pops out the front, and you should be able to access the HV splitter screws from upside down as well.'
Send them in using these instructions:
http://www.curtpalme.com/ContactUs_Shipping_Parts.shtm
doubleuf
Posted: Fri Jan 23, 2009 5:36 am    Post subject:
Thank you and I will check it tonight. I wonder after I've taken out the splitter and unpluged the RGB HV lines, should I turn on the power and check if the error gone?
WF
Posted: Fri Jan 23, 2009 5:50 am    Post subject:
You can try that if you want. Only disconnect the RGB HV leads going to the tubes, leave the one coming from the HV transformers connected to the splitter, otherwise you'll have a one time smoke and light show. Smile
doubleuf
Posted: Fri Jan 23, 2009 5:57 am    Post subject:
There are five holes in the spllitter and only four of them are used, I just want to confirm, the RGB lines are the three in the center, i.e. the five holes are in the order: line from the HV transformer, R line, G line, B line and empty hole?
WF
