Bill in Beaumont
Joined: 28 Sep 2006 Posts: 62 Location: Beaumont AB Canada
| Posted: Fri Aug 24, 2007 5:18 pm Post subject: Barco Data 801S Port 3 question |
I decided to try and use port 3 to connect my HDFury & PS3 on my 801S but it does not appear to work. No blue light on the Fury, no image on screen. The Fury does work on port 5 but I need this input for the output from my video processor used for my cable box and dvd player.
As far as I can tell all the boards are installed (no empty slots - see picture).
Are there any switches or jumpers that need to be set?
Does port 5 need to be disconnected?
Bill in Beaumont
| Posted: Sat Aug 25, 2007 8:59 pm Post subject: Re: Barco Data 801S Port 3 question |
| Bill in Beaumont wrote: | I decided to try and use port 3 to connect my HDFury & PS3 on my 801S but it does not appear to work. No blue light on the Fury, no image on screen. The Fury does work on port 5 but I need this input for the output from my video processor used for my cable box and dvd player.
Thanks |
Well I have confirmed that I do have the proper board in the projector but I'm still not getting any signal via the Fury. I'm beginning to think the problem is in the Fury itself; I hooked it up to port 5 and no luck there either even though it worked on this port before. Looks like I'll be finding out how well HKMod stands behind their warranty.
| Posted: Sat Aug 25, 2007 9:07 pm Post subject: |
Have you checked the signal going into the Fury
Bill in Beaumont
| Posted: Sat Aug 25, 2007 9:10 pm Post subject: |
Yes
oliverg
Joined: 15 May 2007 Posts: 800 Location: Melbourne, Australia
| Posted: Sun Aug 26, 2007 4:16 pm Post subject: |
Are you getting a succesful HDCP handshake with your source device? (what color is the led on the Fury?)
_________________ ( R ) G ( G ) 9 ( B ) 0 ( R ) G ( G ) 9 ( B ) 0
