Slightly OT, but need some help re: rear projection tvs
Ridebreck
Posted: Thu Aug 23, 2007 6:13 pm    Post subject: Slightly OT, but need some help re: rear projection tvs
There is a local guy selling a Zenith PVY4661DT rear projection tv for cheap due to a reported misconvergence that he doesn't want to pay to fix. I have been busting my ass trying to find some information on this model and have turned up nothing. I'm not expecting an HD-ready display or anything, but figure that this could still be a pretty good deal is all that's needed is some service menu work with the convergence controls.
I was hoping that someone here might have better luck at finding some info on that model (or even the series).
Curt, did you ever work on the rear projection units? I didn't know if Zeniths might be notorious for certain parts going out on them. I know that Dave's "aka Cine 8 Onyx" hasn't given him any fits, but I have a feeling that this tv is a few years older and has probably been ridden a bit harder.
Any help would be appreciated.
"Hooray Beer!!"
Posted: Thu Aug 23, 2007 6:28 pm    Post subject:
I won't know until I see pix, but a lot of these are based on teh PRO 851 sets. Take a look at the tips section and see if the convergence panel is the same as in his set. If so, I have lots.
BradTheAggie
Posted: Thu Aug 23, 2007 6:39 pm    Post subject:
All I could find is this, thru a dejanews search...
http://groups.google.com/group/sci.electronics.repair/browse_thread/thread/f828014ea83b642b/405e7efe187612f8?lnk=st&q=PVY4661DT+&rnum=4#405e7efe187612f8
(bholman on the AVS forum)
Z-Photo
Posted: Thu Aug 23, 2007 7:22 pm    Post subject:
turn it around - take the back and mirror off - stare at it straight on...
then we will talk to you....Smile
Engineer by Day
Photographer by Night
My Portfolio
Posted: Fri Aug 24, 2007 3:42 am    Post subject:
Alot of these RPTV's including this one likes to eat the convergence ic's. I have replaced many of them. I believe on that tv they are ic4008 and ic4009 on the convergence board. They should be STK392-110's. Also check the 4 - 1ohm resistor's on same board. There is also a 5 amp pigtail fuse that feeds that circuit but is probably on the P/S board. Good luck.
