how to connect digital cable box to pj
REGNAD
Posted: Mon Aug 20, 2007 9:10 pm    Post subject: how to connect digital cable box to pj
im running a htpc to my 1252 via vga-rgbhv cable. i would like to get a digital cable box to connect to the same pj. what would be the least expensive sollution?
Comcast is the provider.
shannon
to hell with spel cheker
greg_mitch
Posted: Mon Aug 20, 2007 10:33 pm    Post subject:
Kimcoder with a componet cable from the cable box to the Kimcoder and then a vga to rgbhv cable to the second input on your 1252. Of course if you don't have second input then you will need an rgb switcher like a KVM or a NEC ISS switcher, etc.
REGNAD
Posted: Tue Aug 21, 2007 1:04 am    Post subject:
whats a kimcoder?
Heywood Jablome
Posted: Tue Aug 21, 2007 11:32 am    Post subject:
Kim (buen, a member here and @AVS) from Crescendo Systems makes arguably the best (commonly) available reverse transcoder for Component->RGBHV conversion.
That said, your least cost (and most flexible) solution may be an HDFury (assuming your cable box has DVI/HDMI output.)
This will also allow you to hedge against obsolescence, as more and more sources turn digital-only (at least on the HD side.) Kimcoder is still HD Analog (component) to HD Analog (RGBHV.)
greg_mitch
Posted: Tue Aug 21, 2007 11:34 am    Post subject:
Really you should find out what the outputs are on the cable box you are getting before you make your decision.
Heywood Jablome
Posted: Tue Aug 21, 2007 11:47 am    Post subject:
I always forget one critical sentence! Left that one kinda assumed...
What he said... Really. Outputs from your sources will drive your transcoding decision...
Your 1252 requires RGBHV (computer-style) high res input, which the Kimcoder will provide from HD Analog Component sources and the HDFury (along with a few other, less generally available solutions) will provide from DVI/HDMI sources.
REGNAD
Posted: Tue Aug 21, 2007 1:08 pm    Post subject:
i'll check the cable box and see what it has....
thanks for all your help.
shannon
Heywood Jablome
Posted: Tue Aug 21, 2007 1:13 pm    Post subject:
Hmmm.... also assumed was that your cable box is an HD cable box. Digital cable may also be SD, which means you would have to consider a scaler rather than a transcoder. Are you talking HD or SD?
REGNAD
Posted: Tue Aug 21, 2007 1:19 pm    Post subject:
good point, it will be an HD box but both HD and SD will be watched. how about outputting from the cablebox into my htpc, upconverting SD, and passing to pj? is there a pc vid card with Digital vid inputs? or component inputs?
Heywood Jablome
Posted: Tue Aug 21, 2007 1:28 pm    Post subject:
With a 1252, you can probably live with the HD cable boxes' internal SD->HD scaling options. If you had a super high-end projector then you would probably benefit from external scaling, but with anything in the entry level you can probably just run with 1080i right out of the cable box.
REGNAD
Posted: Tue Aug 21, 2007 1:49 pm    Post subject:
so with scaling out of the way, i just need to figure out the best way to connect the cablebox to pj. depending on the cablebox i coud get an HD-Fury or could i use a WinTV-HVR-1600 and let it replace the cablebox?
Posted: Tue Aug 21, 2007 3:43 pm    Post subject:
http://www.hauppauge.com/pages/products/data_hvr1600.html
From what I could tell, the WinTV is OTA and *analog* cable. It also supports clear QAM, which means if your cable company sends any unencrypted digital content (locals in HD for instance), you could get those off the cable, too. All the rest of the digital programming, and especially any HD or premium programming - no dice.
Go with a cable box - especially if you can get one with a DVR. That way, you can spend time actually WATCHING movies on your projector instead of jacking around with drivers, software, video card, sound card, reclock, powerstrip, etc.
Heywood Jablome
Posted: Tue Aug 21, 2007 3:44 pm    Post subject:
Depending on the cable box you could use either an HDFury (for digital DVI or HDMI outputs) or a Kimcoder (for HD analog component.)
Using an HTPC ("home theater personal computer") as a TV tuner opens a whole can of worms that I can't discuss, both for want of experience and lack of time. Suffice it to say that the software that works with commodity tuner cards is as a whole pretty poor (in my limited experience) and the obsolescence rate will leave you high and dry eventually.
My advice: Get an HD digital cable box and service from your cable company and save the WinTV money for an HDFury.
REGNAD
Posted: Tue Aug 21, 2007 3:57 pm    Post subject:
just checked my current cable box. it's an Explorer 8300hd by scientific atlanta. i dont plan on getting a dvr model for my theater, for now i will asume that the non dvr model will have the same vid connections.
this model has:
1-hdmi
2-1394
1-sata
i know what i can do with the hdmi, but does anyone know what can be done with the other outputs?
wkomassa
Posted: Tue Aug 21, 2007 4:55 pm    Post subject:
I have an Explorer 3250HD with component out into my 1252 with an IFB-12 and the SD picture is watchable. I stretch the picture to use the whole 16:9 raster and try to watch as little SD as possible. It does work though, and the Explorer boxes do allow the option to just set the output to 1080i which is how I have mine set up. Like I said, the SD picture is watchable and varies greatly from station to station based on how crappy your cable reception is. But it does work. I've never owned a scaler, but scaling crappy SD cable signal seems a lot different than scaling 480i from a less-noisy video source.
I'm getting a Fury, so if you want the IFB-12 - somebody suggest a reasonable price and you can have it.
Heywood Jablome
Posted: Tue Aug 21, 2007 5:10 pm    Post subject:
this model has:
1-hdmi
2-1394
1-sata
The 8300 is a DVR, but that feature may be disabled (or separately subscribe-able.)
1394 outputs are "Firewire" and may or may not be enabled... these have their own mechanism of copy control and can be used (if enabled, and within the constraints of copy control) to transfer stuff onto a Firewire-enabled PC (Again, I tried and failed to do this... my F'd up cable company refuses to enable 1394 despite the law.)
Check the excellent info at AVS regarding 5C constraint tokens, D-VHS decks and emulator software, etc.
What you probably aught to do is just get an HDFury and run with it... then you can get a cheap HDMI switcher for PS3/XBOX360/HDDVD/BlueRay switching.
Heywood Jablome
Oh, and the external SATA is for expansion hard disk capacity for the DVR function.
wkomassa
Posted: Tue Aug 21, 2007 5:14 pm    Post subject:
Real-life experience - my 8300HD's HDMI output is enabled. Other users in my area (Time Warner Cable ~ Milwaukee, WI) also report success with this box. The 8200HD though, they haven't enabled HDMI for whatever reason.
REGNAD
Posted: Tue Aug 21, 2007 5:55 pm    Post subject:
cool, thanks for all the help!
shannon
greg_mitch
Posted: Wed Aug 22, 2007 2:29 am    Post subject:
I have a motorola box and I don't think there is an option for outputting the SD at 1080i...I might just be stupid and not looking at the menu options though.
I know how it is set up now that the projector switches to 480i if I venture away from the HD channels.
