XP Networking Issue
AFryia
Posted: Mon Aug 20, 2007 1:06 am    Post subject: XP Networking Issue
I did a Nuke and re-load of my HTPC XP MCE2005 a while back.
I can access the internet just not my home network even though I see the network (workgroup). From any other machine I can see the HTPC on the network, just can't access it.
The help guide says the TCP/IP is corrupt. If that is the case how can I access the internet but not the network ?
Posted: Mon Aug 20, 2007 8:59 am    Post subject:
You are talking about the LAN, right? I take it that you are probably using a switch, or a router with built in switch. You are able to access the Internet, meaning that the router is allowing communication from a port on the switched-LAN to the WAN port. Can the other compuers on the LAN access the network?
Ok, so the other PCs on the LAN can see the MCE PC on the LAN. Have you 'shared' any of the drives on the MCE so that other computers can access it? Did you use the same password with the same account on the MCE PC that you used on the other PCs?
aspec2
Posted: Mon Aug 20, 2007 12:28 pm    Post subject:
Is "guest" active?
Walt
AFryia
Posted: Mon Aug 20, 2007 11:16 pm    Post subject:
Yes an 8 port VPN router/switch.
Yes all the other computers can access the share folders on any other computer (Win95, Win98, 2-XP Home). I can see the HTPC on the network but not it's share folder
I'm not using a password on any computer. (well the old WIN98 machine still does)
aspec2 wrote:
Is "guest" active?
Yes
Darren Wadsworth
Posted: Mon Aug 20, 2007 11:18 pm    Post subject: Re: XP Networking Issue
What do you mean "can't access it"? What exaclty are you trying to achieve?
Darren
"DLP is the official ESPN on ABC HD telecast sponser of college football"
AFryia
Posted: Mon Aug 20, 2007 11:33 pm    Post subject: Re: XP Networking Issue
Darren Wadsworth wrote:
What do you mean "can't access it"? What exaclty are you trying to achieve?Darren
I can see the computer Icon under the workgroup. If I click on it I get an access denied dialog.
I'm doing nothing complex just transferring files to and from, printing to the shared printer.
Posted: Tue Aug 21, 2007 9:46 am    Post subject:
aspec2 wrote:
Is "guest" active?
Yes
Ok, so the computer can be seen in the Network Neighborhood, but you get Access Denied when trying to access the visible Shared folder. Try this. Create a folder called mcetemp on the MCE C:\ drive and share it. Now try to access it from the other computers. Whether you are successful or not, perform the same experiment on the other computers.
Getting an Access Denied is a simple permissions-authentication condition that is not being met. I use accounts on all computers WITH passwords, so I am not sure about the open-access condition you are presenting.
Darren Wadsworth
Posted: Tue Aug 21, 2007 2:58 pm    Post subject:
If you are only seeing the computer icon and not a drive icon share, you will not have access. If the drive is definatly shared on that local PC, then you have a permissions problem. In that case you need to add the username from the PC you are trying to access from, to the security list of users on the shared PC.
Darren
Posted: Tue Aug 21, 2007 3:30 pm    Post subject:
WanMan is probably right -- it's a permission thing. Permissions in Windoze networking, especially across Win 9x - 2k - XP, are a mess.
But just to be sure: it's clear TCP/IP is working on the HTPC, since it can reach the net. But you don't always use TCP to access other systems on the LAN. You might be using NetBIOS, and that could have a problem. Try pinging from other systems to the HTPC & vice versa. ping is an IP protocol but it should at least help you figure out if the problem is low-level connectivity problems or permissions. If you can't ping, you may have a deeper problem than permissions.
GEBrown
Posted: Tue Aug 21, 2007 7:02 pm    Post subject:
Harrumph!!!! ICMP is an IP protocol. Ping is an application that uses ICMP protocol, as does traceroute, among others!
http://en.wikipedia.org/wiki/Ping (if you can believe anything in wikipedia Very Happy )
AFryia
Posted: Tue Aug 21, 2007 11:25 pm    Post subject:
TCP/IP is loaded, MS says it loads as part of the core operating system and can't be unloaded. Confused None of my XP machines (3) have the NetBIOS protocol loaded and two of the machines work fine.
If I ping from another computer or direct from the router (via router utility) i get a time out. Strange because the router see's the HTPC and assigns it the address I used for the ping.
Posted: Wed Aug 22, 2007 12:52 am    Post subject:
All I can say is that I ran into a similar problem once when my wife's computer was connected wirelessly through a router. The network browser just couldn't resolve the problem. Even when I reloaded the operating system I wound up having to remove the wireless adapter. Seems that the Microsoft network stack was just a POS--and I do not mean packet over sonet.
