Sony 1272q convergence
wallace123456
Posted: Wed Aug 15, 2007 2:32 pm    Post subject: Sony 1272q convergence
This question is along the same line as the post from "donr". Is there a way to converge a Sony 1272q using an exterior pattern instead of the crosshatch that is built in the pj? Whenever I go into the test mode, the internal patterns are displayed.
I then end up doing a little convergence via the internal source, switching to external test pattern to see if the adjustment was good, then back to internal and so forth.
wallace
Posted: Wed Aug 15, 2007 4:13 pm    Post subject:
Yep... I can't remember for sure at the moment, but I think if you hold down the "test" key again for same 5 or 6 seconds AFTER you're in service man mode, and in zone convergence mode, it will then display the external source. It's a little tricky - you need the manual so you know which zone you're adjusting because you don't get the visual feedback of the flashing square to tell you visually which zone you're adjusting. You just get a "zone 5" message or whatever.
wallace123456
Posted: Wed Aug 15, 2007 5:16 pm    Post subject:
Interesting! Always worth a try.
I looked over the manuals, but could not find anything that says it can be done.
Thanks.
wallace
GEBrown
Posted: Wed Aug 15, 2007 5:29 pm    Post subject:
Yes, that is correct, though I'm a little hazy on the details since I haven't run a 1272 for a while.
But, yes, you toggle with the TEST button.
Also, the internal registration block (memory block) used will be the one that conforms to the input horizontal frequency, not the default registration block 4 (unless the external frequency happens to match).
There is a reference to all of this near the back of the manual, but yes, it is somewhat obscure.
HTH
Gary
Edit: I just spent the last 30 minutes looking through the manuals and I can't find it - but I'll bet SonyNut knows.
Vibe
Posted: Wed Aug 15, 2007 8:14 pm    Post subject:
You press the test button to toggle between the different test patterns. The last one is your source picture. When in zone and exterior source, the rectangle for the area you are working in flashes on the screen for a second so you at least know where you are.
wallace123456
Posted: Wed Aug 15, 2007 8:43 pm    Post subject:
But, how do I do convergence using an external pattern?
wallace
Sonynut
Posted: Wed Aug 15, 2007 9:50 pm    Post subject:
Actually, holding down TEST for 5 secs or so while in any convergence mode will display the source pattern. Then you just adjust just as you would with the internal patterns. Big difference as said earlier is that while on ZONE adjustment mode, it wont highlight the area you are adjusting. You either have to look at the manual to see what area you are adjusting or remember all 21 points.
1272 Stack coming soon:)
wallace123456
Posted: Wed Aug 15, 2007 10:55 pm    Post subject:
Cool! Just got home, so, need to get a beer, and give this a try.
Got your pm; we'll work something out. I need to get rid of 1 of these 1272 beasts!!!
I now have 6 pjs in what is supposed to be my "home theater". Looks more like a crt junk-yard... Confused
THANKS!!
wallace
wallace123456
Posted: Thu Aug 16, 2007 12:59 am    Post subject:
Gary, Vibe and Sonynut,
Excellent info!!! I am there. IN other words, it works!!!!
Thanks a million!
Now, back to converging.... 8)
wallace
wallace123456
Posted: Thu Aug 16, 2007 2:26 am    Post subject:
Well, I'll just be damned!! Being able to do convergence on an external source is the best thing since sliced bread! Although IMHO, I did a pretty good job using internal so far. Problem was that it took hours to do; switching back and forth, back and forth, back and forth...
Too damn cool!!
Thanks.
wallace
Vibe
Posted: Thu Aug 16, 2007 4:07 am    Post subject:
Ahh, it's been a while since I've played with a Sony what with all these Barcos layin' around.
