10PG bright on start up.
deronmoped
Posted: Mon Jul 23, 2007 5:46 am    Post subject: 10PG bright on start up.
When I fire my 10PG up the green and red tubes are too bright. The image on the tube looks like it is the correct brightness, it's the areas that should be black that are lit up. It used to be the green that only did this, now the red does it too. The brightness problem goes away after a minute or two.
I'm thinking it's probably some caps that are going bad, anyone know where I should start looking?
Thanks, Deron.
Posted: Mon Jul 23, 2007 11:02 am    Post subject:
Does it come good after the memory kicks in? Or after a warmup.
If it's the first it sounds like the white balance is out and when the AKB kicks in if sorts it.
Or if after a warmup, then you have some tired caps, or it could be the tube.
My XG takes 5mins for the colours to sort themselves out. I've changed everyboard, I think it's the tube.
deronmoped
Posted: Mon Jul 23, 2007 3:57 pm    Post subject:
Mark
The AKB is what I tried first. I tried using the white balance to fix it, but that did nothing.
If I run the PJ often enough the problem is not there. Pretty sure it's some caps, just need to know where to start looking.
I guessing that I should start looking in either the video chain or the G2 section.
Deron.
Tinman
Posted: Mon Jul 23, 2007 8:52 pm    Post subject:
Try the 10uF 160volt or better caps on the video output board.
Marc
This space for rent.
deronmoped
Posted: Fri Sep 14, 2007 11:54 pm    Post subject:
OK guys where else should I look, the video out board's caps should be good enough. The one open one I replaced fixed the minor streaking.
It acts almost like the G2 is boosted for about a minute and then it slowly goes back to normal. Another way to describe it is it's almost like the brightness is cranked all the way up and then it slowly comes down after about a minute.
Deron.
Tinman
Posted: Sat Sep 15, 2007 3:34 am    Post subject:
Deron, check the caps on the wave board for esr, and the small ones around the oscillator IC on the deflection board. Sometimes you can even SEE them leaking.
Marc.
deronmoped
Posted: Sat Sep 15, 2007 10:59 pm    Post subject:
Marc
I did find a bad one on the wave board, also the system board. I replaced them, have to do some testing to see if that did the trick.
Deron.
deronmoped
Posted: Wed Sep 19, 2007 5:16 am    Post subject:
Looks like the problem is fixed, I have started the PJ up several times and did not see the added brightness.
Marc, what made you think it was the wave board.
Deron.
Tinman
Posted: Wed Sep 19, 2007 8:16 pm    Post subject:
Deron, the caps on the wave board can cause weird problems. I had trouble with my own PG9 until I re-capped the wave board. Rock steady afterwards. The wave board controls most of the projectors functions, and others pass through it.
Just a hunch.
Marc
