"Ripple" in 8500 raster
Posted: Thu Jun 28, 2007 4:21 am    Post subject: "Ripple" in 8500 raster
I've got a relatively minor but very annoying problem with my 8500. There is a "ripple" in the raster that produces darker/lighter stripes across the screen, making it look almost like big fat scanlines. This happens with all the inputs I've tried, including none. It appears on all three colors, and it's identical on all 3 -- i.e. I see the ripples clearly on a full white screen with no color variations. That says to me that the 3 colors are all getting the same ripple in some input, otherwise they'd ripple at different times/speeds and you'd see colors on a white screen. It's present immediately after a full reset, so it's not like the common "banding" problem.
I can't quite tell if it's caused by a variation in thickness of the scanlines, or a variation in spacing. It's very difficult to get a clear picture of it, especially close-up, but I've attached a few to give you an idea what it looks like.
With Dragan's help I've tried to isolate it by swapping out components. So far I've swapped out:
* VDM
* VIM (swapped in an old 8000 VIM, looked awful, but still had the ripple)
* DPB (the deflection daughterboard on the CLM)
* Neckboard (put an 8000 VNB on the green but it still had the ripple)
* LVPS
I tried unplugging the focus module. The ripple was harder to see on a blurry raster but it was still there. I removed the color correction module, no change.
I don't think it can be the CLM, since I assume that's all digital. As I understand it, the CLM sends commands to the DPB, which converts them into waveforms that the VDM amplifies -- correct?
I can't think of too many other things to try. About the only likely suspect left is the HVPS, but Dragan doesn't have a working spare to try. I may try dropping my HVPS into one of his machines, but he's an hour away so I might not get there right away.
Help!! Any ideas?
Gary
Here's a picture of the internal grayscale pattern so you can get a sense of the size of the artifact.
 Filesize:  54.44 KB
 Viewed:  6757 Time(s)
Red raster. It's more visible from a distance but you can see it here.
 Filesize:  48.64 KB
Close-up of the raster. You can just barely see a darker stripe every 8 scanlines. This is with no signal input, so whatever resolution the 8500 uses with no input.
 Filesize:  29.81 KB
Posted: Thu Jun 28, 2007 9:06 pm    Post subject:
Hello
Try unplugging convergence and stig yokes for one color and see if any difference.
Posted: Thu Jun 28, 2007 9:35 pm    Post subject:
OK, convergence would be the orange/purple/black wire going to the center board on the heatsink, and stig would be the blue/purple/white wire going to the board on the red-CRT side -- right?
Posted: Thu Jun 28, 2007 10:45 pm    Post subject:
Yes. It can also be a ground loop or something in the signal. Disconnect the input ( I know you said you tried it with no input, but did you actually disconnect the BNC connectors so that the set is sitting there with nothing but the power cord connected?
Then yes, disconnect the conv. and stig leads.
If not, I'd try the HDM or LVPS and HVPS as suspects.
Posted: Thu Jun 28, 2007 11:15 pm    Post subject:
Aha!! Now we're gettin' somewhere!
I disconnected all the input BNCs and powered it up -- ripple was still there.
Powered off, pulled the red stig/conv, and powered up -- and the ripple is **GONE**!!
So: what does this tell us? What do I do now?
Thanks guys!!!
Posted: Thu Jun 28, 2007 11:30 pm    Post subject:
Thanks guys!!!
Hello
Stig and convergence are driven Analog by waveforms from the control board, can you try another control board?
Posted: Thu Jun 28, 2007 11:43 pm    Post subject:
The CLM? That's one of the few things I haven't swapped out. Dragan and I popped all the chips on it and cleaned them with De-Oxit, but we didn't try a different one in my set. Guess that's next...
CZ Eddie
Posted: Fri Jun 29, 2007 12:14 am    Post subject:
Gary, did you ever figure out the 1/3 image square box thing?
Good going on tracking down the ripple, btw!
Posted: Fri Jun 29, 2007 12:29 am    Post subject:
I had also suggested to swap out the CLM. It can be a problem if the rail caps become leaky.
Also, If it is the caps on the CLM, It's doing more harm to the image than what you've seen so far. I'm surprised you're not also having focus problems
Posted: Fri Jun 29, 2007 2:13 am    Post subject:
Yes Mike, I remember you suggested the CLM as a possibility. I've just had so many possibilities it's taken a while to try them all. Smile
If it's caused by the CLM, do you think it would be worthwhile doing some maintenance / cap upgrading before I get myself a different CLM? I'm not having any focus problems that I've noticed.
Eddie, I realized I had some brightness issues with my DVD player. When I increased the DVD brightness and lowered the projector brightness, the square disappeared.
Posted: Fri Jun 29, 2007 2:21 am    Post subject:
I can send you the caps to replace - shoot me your address. I'll also have to take a picture of the board so that you'll know where they go. You'll have to very careful when randomly capping th CLM, because the wrong or two high a value caps, have been known to shut it down.
I also think I've posted the cap upgrade on the maintenance thread. But you'll probably do better with the caps I have. plus they'll not going to cost you anything.
Posted: Fri Jun 29, 2007 2:32 am    Post subject:
How can I turn down an offer like that!? Thanks Mike!!
jcmccorm
Posted: Tue Jan 22, 2008 10:47 pm    Post subject:
Any update on this Gary? I've got an 8500 that I just set up for my brother-in-law that does this. I hadn't tried pulling the convergence connection yet but it looks like the same thing. Did the CLM update/upgrade fix it?
Cary
Posted: Tue Jan 22, 2008 11:11 pm    Post subject:
No, Mike's updates didn't help, unfortunately. Curt sent me a different CLM and that one solved it. I think Curt said my CLM didn't show the ripple in his test projector??
I still haven't seen it in action -- I've had a G70 in the HT for a few months but I plan to put the 8500 back in service fairly soon -- but the ripple was clearly visible on the tube face before, and now it's not. So I'm 99.99% sure it's finally fixed, yay!!
Posted: Wed Jan 23, 2008 1:50 am    Post subject:
Mike that cap upgrade was posted on avs in your Marquee 02 vim success thread:
http://www.avsforum.com/avs-vb/showthread.php?t=869329&page=1&pp=30&highlight=clm+mods
Remember you sent me the caps and i accidentaly put them in with the wrong polarity and messed up the board.
