Can I use this as a temporary screen?
irridion
Posted: Sat Apr 28, 2007 7:04 pm    Post subject: Can I use this as a temporary screen?
It is white artists foamboard, and it's only $17.00 (Can) for 48x96 !
http://www.currys.com/artistsmaterial/prodinfo.asp?SubcatID=766&catID=4
"...Bainbridge standard white foamboard is ideal for all non-archival mounting purposes (except F351 which is designed for archival use). It is lightweight and easily cut with a sharp utility knife for clean, crisp edges. Its rigid construction makes it a perfect choice for presentations and frameless mounting. It is clay-coated for an extra smooth surface and dual-sided with bright white surfaces. Bainbridge white foamboards are are CFC-free and made available in various thickness and sizes..."
Joust
TV/Projector: Marquee 8501LC
Posted: Sat Apr 28, 2007 7:14 pm    Post subject:
you could.
i think it'll be a bit too reflective and hotspot on you.
try it and let us know.
Order a sample of Willsonart to compare. they will mail you a piece for free. its only 3.5inches by 5 inches but you will get the idea.
Clarence
Posted: Sat Apr 28, 2007 8:27 pm    Post subject:
Several people have reported success in using foamboard as a screen.
Especially if you pick it up locally and handpick a piece without scrapes, smudges, or dents, etc
irridion
Posted: Sat Apr 28, 2007 9:38 pm    Post subject: I'm in
It's less than 20 dollars so I think i'll go buy some tomorrow...how the
!$#(*& am I going to get it home!
Joust
Posted: Sat Apr 28, 2007 10:27 pm    Post subject:
its only 48 inches wide though.
Clarence
Posted: Sat Apr 28, 2007 10:33 pm    Post subject:
IMHO, 48"x85.33" (16:9) at 1080i is ideal for irridion's 1272.
Joust
Posted: Sat Apr 28, 2007 10:38 pm    Post subject:
I defer to your greater wisdom.
I have Zero experience with anything other than my Marquee.
redcorvette_85
Posted: Sun Apr 29, 2007 1:37 am    Post subject:
Before the big DW laminate discovery a lot of people where using Do-able 1/4 4x8 white vinyl panels from home depot. They run around 15 bucks a sheet U.S. give a nice picture without hot spotting. Looks a lot like a melamine sheet, so don't get them confused because melamine will hot spot. The Home depot SKU is 174-278 and it is called a White vinyl panel made by do-able products inc. model #63036. I used one for awhile with a barco 800 and was really impressed with it. I even got HD to cut it for me while I was there to 49x87 for 100 inch diagonal screen. I mounted mine on the wall with mirror hangers so it was really easy to put up. There is a pretty big thread on it on the A site in the DIY screen section if you want to look into it.
irridion
Posted: Sun Apr 29, 2007 4:28 am    Post subject: Thanks
Hey guys thanks for all of the input, just a quick question: Are these materials available in Canada? I can't find do-able at Home Depot here.
ADRIANKELLY
Posted: Sun Apr 29, 2007 5:55 am    Post subject:
You can certainly find them at a art supply store or call your local museum and find out their supply source . I found a similiar product called Gatorfoam and it has served me well for 4 months . If it was in stock in Anchorage you should be able to find it anywhere .
If You Choose Not To Decide You Still Have Made A Choice .
