Looking to capture, hold and retransmit IR commands
Ron R
Posted: Mon Apr 16, 2007 11:37 pm    Post subject: Looking to capture, hold and retransmit IR commands
I have a multi-zone sound system(speakercraft), it has a common IR buss, which means while it is sending IR commands it can not receive IR commands.
So for what I want to do, control 1 zone from another zones keypads, I need to capture the command, hold it for 10seconds, then retransmit it when the buss is no longer busy.
I know you can do this with computers, but looking for a simpler plugin/play solution.
The IR commands will vary so its not a set command.
Found this
http://www.zbasic.net/appNotes/AN204.pdf
I guess I could build something like that but I think there should be an off the shelf product.
Anyone seen something that will fit this description in their travels?
Never put off until tomorrow what you can put off until the day after tomorrow -- Mark Twain
paw
Posted: Thu Apr 19, 2007 10:42 pm    Post subject:
Does Speakercraft have anything? I know they've got a ton of speakers.
Universal Remote has the MSC-400
http://www.universalremote.com/product_detail.php?model=108
It might do the trick. It's a pretty slick box.
Smart Home has lot of IR products
http://www.smarthome.com/_/Remotes_IR_Distribution/IR_Distribution/_/5/1Rj/nav.aspx
Xantech is another company heavy into IR stuff
http://www.xantech.com/
Aubrey
Ron R
Posted: Mon Apr 23, 2007 2:03 pm    Post subject:
Actually the Speakercraft techs asked me to let them know if I figured anything out, that could do this.
