James1988
| Posted: Sun Apr 12, 2026 10:43 am Post subject: Barco cine 7 issues |
Hi everyone, I recently bought a barco cine 7 projector and it seems to have a couple of issues.
1) the raster extends horizontally past the edges of the visible tube so I'm worried this will be hitting the non cooled part of the tube. I have reduced the horizontal size all the way down to zero and the internal grid pattern does reduce in size, but the grid still over scans on both sides horizontally. Vertical size is fine, I can get the whole grid inside the tube face no problem.
2) the image seems unstable, the grid judders slightly on all three CRTs. I'm guessing this is a filter cap issue so will check all the caps but not sure if this is a problem anyone else has encountered before.
3) the brightness of the red CRT seems to reduce occasionally, I can get it nice and bright again by adjusting settings so still works, just seems to have a mind of it's own
Any help or advice would be greatly appreciated. I've checked for error codes and there are none flagged.
kal Forum Administrator
James1988
| Posted: Sun Apr 12, 2026 2:50 pm Post subject: |
Thanks for the reply, I followed the installation manual and also checked the guides on the main website but I just can't reduce the horizontal size of the raster enough for some reason. I'm suspecting that it's a fault with the projector (given it seems to have other faults too) but will double check the guides and manual again.
James1988
| Posted: Sun Apr 12, 2026 4:15 pm Post subject: |
Ah brilliant, thanks a lot for your help, I'll check to see if I can locate mechanical controls. Great website by the way, extremely helpful thanks 👍🏻
| Posted: Sat Apr 18, 2026 11:01 pm Post subject: |
There should be a master width control, on the power supply. THe 708 service manual is on the website for download. It's marked P8, a small trimpot, in that service manual. I think the Cine 7 is similar or identical.
James1988
| Posted: Sun Apr 19, 2026 5:53 am Post subject: |
Yeah I found the master width control pot, but also found some burn marks on the PCB next to a couple of resistors so have a fault somewhere in the power supply which I need to try and trace down. Great news there's a service manual for the 708 as I couldn't find one for the cine 7 anywhere so hopefully that will be a big help
| Description: |
 Download |
| Filename: |
IMG-20260419-WA0000.jpg |
| Filesize: |
172.9 KB |
| Downloaded: |
9 Time(s) |
