Sony VPH-1292Q C Element Question
harry27
Posted: Mon Jan 19, 2026 3:53 am    Post subject: Sony VPH-1292Q C Element Question
Can you use the C Elements from a Sony VPH-1292Q in other 9" CRT projectors like a Sony VPH-G90?
Hulio
Posted: Mon Jan 19, 2026 6:50 am    Post subject:
Yes, all HD-10 family lenses shares the same C-elements.
It is known that the green C-element Sony used in their 9" crt's, were light green color (to win some light output from the green tube).
To have an accurate color calibration, you want the darker green version of the green C-element.
harry27
Posted: Mon Jan 19, 2026 8:56 pm    Post subject:
To my knowledge only the Sony G90 had the light green C Element.
The G70 and 1292Q had the normal dark green C Element. However I could be wrong about the 1292Q.
Posted: Tue Jan 20, 2026 3:27 am    Post subject:
If you switch from light to dark C element, you'll need to recalibrate. I never had an LC projector, but I experimented with colored gels on the front of the lens. The darker gel gave the correct colors, but only after recalibrating.
harry27
Posted: Tue Jan 20, 2026 9:58 pm    Post subject:
This is true, you always have to recalibrate when making a change to the color filtering. That isn't a hard task if you already have the equipment and software.
garyfritz what color gels did you try? I'm interested in checking them out
