station_equation
| Posted: Sat Sep 06, 2025 7:02 pm Post subject: Calibration order of operations |
I've got a G90, a Radiance 2144, and then various media devices (LD player, BD player, and an AppleTV). Since both the G90 and the Radiance are infinitely adjustable to set up color systems, which do you do first (meaning, do you even adjust the G90 bias, gain, and gamma at all)? I would have liked to use the test patterns in the 2144 since the signal generator I have is only RGBHV.
Do I need to bite the bullet and get an HDMI signal generator to calibrate the G90 individually, then refine on the Radiance? Or just use the 2144 signals to rough calibrate the G90, and then fine tune in the Radiance itself?
Then after all that, use the various test discs for the source devices? I've got both Video Essentials on LD and the AVS bluray.
_________________ Jeremy
Sony G90 / Pioneer HLD-X9 / Radiance 2144 / Marantz SR5011
