1080p@72hz & 1080p@48hz with VP50Pro?
that1crzywhtguy
Posted: Mon Mar 04, 2024 5:46 pm    Post subject: 1080p@72hz & 1080p@48hz with VP50Pro?
Hi all again! I'm following up along similar lines as this post: https://www.curtpalme.com/forum_archived/viewtopic.php@t=43258.html
I think I misunderstood the capabilities of the VP50 and VP50 Pro. Doesn't seem like it can do 1920x1080@72hz. That being said, people have posted in the past(https://www.avsforum.com/threads/1920x817-72hz-other-then-the-vp50pro-can-any-other-vp-do-this.1101266/#post-15401740) that it can handle 1920x817p@72hz...
My first question is... How? I know I can edit resolutions in the menu, say dropping 1080 to 817, but how do I get 72hz to work with this? Anyone with firsthand experience on this?
Secondly, I've seen it mentioned by a few (http://www.curtpalme.com/forum/viewtopic.php?p=221593#221593) that reducing porches on 48hz gets the flicker way down. Anyone got specific modeline info on that?
Thanks so much!
virusc
Posted: Wed Mar 13, 2024 10:14 pm    Post subject:
How are you getting the analog signal at 72hz at either 1080p or 817? Do most of the HDMI or DVI to RGBHV do that? I thought most are fixed at the normal resolutions and refresh rates?
Reducing the porches I thought was for ringing and overlap? I don't see how a porch setting will effect flicker as the CRT is still being painted at the same rate with the same fixed decay isn't it?
that1crzywhtguy
Posted: Sat Mar 23, 2024 2:16 pm    Post subject:
I'm not using an hdmi/dvi to rgbhv at all. I'm taking the output from my vp50 pro right to the dvi card.
I got it all working with 817p@72hz btw. Looks incredible. Set up 48hz too got 1.78:1 content and only in very bright scenes does it look flickery.
