Bleeding Vph-d50
that1crzywhtguy
Posted: Sat Nov 18, 2023 6:27 am    Post subject: Bleeding Vph-d50
Hi all! I'm doing some checking out of some long dormant d50s. I don't see bubbles, so I was trying to figure out the bleed procedure... But they have big rubber expansion thingys? Anyone ever bleed these? Is it actually unnecessary on these? Any info would be awesome!
Posted: Sat Nov 18, 2023 2:13 pm    Post subject:
Have you read this?:
http://www.curtpalme.com/Bleeding_CRT_Tubes1.shtm
that1crzywhtguy
Posted: Sat Nov 18, 2023 4:42 pm    Post subject:
Indeed I have. The d50 is very different from this. It seemingly has an expansion tank up top with the rubber dome thing. I know these are designed to not need bleeding, but there is some pressure built in those from not being used.
that1crzywhtguy
Posted: Fri Nov 24, 2023 8:58 pm    Post subject:
I did figure it out... And even a cheater (non advisable) way. I think they weren't really intended to be bled due to that expansion tank. I just didn't want the pressure to get TOO high.
