Barco 808S fault
bluemoonhu
Posted: Sat Jan 21, 2023 1:06 pm    Post subject: Barco 808S fault
This is a Barco BD808S fault machine. When the machine is started, the LED lights on each board will show green light, and the tubes can emit a high voltage sound of "zi zi", but the three tubes have no image, I suspect that the drive board is faulty
 Filesize:  82.05 KB
 Viewed:  3578 Time(s)
bluemoonhu
Posted: Sat Jan 21, 2023 1:16 pm    Post subject: Barco 808S fault
drive board( fault 808s)
 Filesize:  71.33 KB
 Viewed:  3576 Time(s)
bluemoonhu
Posted: Sat Jan 21, 2023 1:18 pm    Post subject: Barco 808S fault
drive board (good 808S)
 Filesize:  383.7 KB
 Viewed:  3575 Time(s)
bluemoonhu
Posted: Sat Jan 21, 2023 1:21 pm    Post subject:
I don't know how to solve it
Posted: Thu Jan 26, 2023 10:22 am    Post subject:
Have you checked the EHT board for a RED LED. Look down the hole in the top of EHT to see LED.
bluemoonhu
Posted: Thu Jan 26, 2023 2:51 pm    Post subject:
If the EHT board is broken, the tube will not have high voltage sound .
Posted: Thu Jan 26, 2023 8:37 pm    Post subject:
Very true. However it does sound like an high voltage issue. I would check the EHT quad and splitter. I have heard arching from a quad and internally in a splitter.
Have you done that?
bluemoonhu
Posted: Fri Jan 27, 2023 1:13 am    Post subject:
Have you done that?
OK, I will check。Thanks!
bluemoonhu
Posted: Mon Jan 30, 2023 1:27 pm    Post subject:
I replaced the EHT quad and splitter,I don't know whether they are in good condition.They have been idle for many years . After the machine was started, I found that the red light in the EHT board was on。
bluemoonhu
Posted: Mon Jan 30, 2023 1:28 pm    Post subject: Barco 808S fault
The EHT board
 Filesize:  162.82 KB
 Viewed:  3462 Time(s)
Posted: Tue Jan 31, 2023 8:12 am    Post subject:
Okay so now we get to the issue. Which is an EHT issue.
I have attached a Scan Fail Circuit so you can see the components that might cause the red LED.
ScanFailCircuit.pdf
Scan Fail Circuit
 Filename:  ScanFailCircuit.pdf
 Filesize:  57.28 KB
 Downloaded:  129 Time(s)
bluemoonhu
Posted: Tue Jan 31, 2023 2:04 pm    Post subject: Barco 808S fault
Can you tell me which component in the EHT board is prone to failure? Thanks!
 Filesize:  301.44 KB
 Viewed:  3434 Time(s)
Posted: Wed Feb 01, 2023 3:11 pm    Post subject:
None of them. The EHT boards are usually very reliable, unless the quadrupler shorts. If one of the EHT red LEDs is on, then you have a problem with the quadrupler or HV splitter... or a shorted tube.
Posted: Wed Feb 01, 2023 4:13 pm    Post subject:
More Barco troubleshooting tips here too:
http://www.curtpalme.com/Troubleshooting_Tips_Barco1.shtm
bluemoonhu
Posted: Thu Feb 02, 2023 12:37 am    Post subject:
Thanks!
bluemoonhu
Thanks!
bluemoonhu
Posted: Thu Feb 02, 2023 4:09 am    Post subject: Barco 808S fault
After replacing the HV quadrupler,start the machine, the tubes can make 'ZI Zi" high-voltage sound, and no red LED lights up in the high-voltage board, but there is no image,Is it the problem with the drive board?
 Filesize:  198.68 KB
 Viewed:  3400 Time(s)
