Runco RS900 - reset lamp hours if lamp won't come on??
Hark22
Posted: Sat May 28, 2022 9:45 pm    Post subject: Runco RS900 - reset lamp hours if lamp won't come on??
We have a Runco RS900. I just replaced the lamp (with factory original bulb), but I can’t get the lamp to start so I can go to the menu and reset the hours.
When I turn the unit on, the green power light blinks for 20 seconds or so and then goes off and the red lamp light comes on. the fan does run for a minute or so - I assume to cool the unit back down.
Is there any way to bypass/reset the lamp hours exceeded using the remote? or some other trick I might be able to try?
Thanks for any suggestions!
Posted: Sun May 29, 2022 11:55 am    Post subject:
Moved to the DIGITAL PROJECTORS forum as the Runco RS900 is a DLP projector. Welcome to the forum!
