Questions about removing "fungus" from vph-1042q
that1crzywhtguy
Posted: Mon Dec 13, 2021 6:25 pm    Post subject: Questions about removing "fungus" from vph-1042q
So I'm getting ready to try this:http://www.curtpalme.com/CLR_Defungus_Sony_Tubes.shtm on my new vph-1042q.
I have just a couple of follow up questions.
1. Is filtering the glycol to reuse it not okay?
2. What is a good source for fresh glycol today?
3. What about tinting? My green and red tubes are both use tinted glycol. I imagine that can't be easily found, so what ink should I use and how accurate do I need to be? Is this kind of just an eyeball it situation?
4. Does anybody have recommendations for the syringe to be used, or maybe a plastic tipped syringe I can use in place of compressed air?
Thanks so much in advance!
Code:
Last edited by that1crzywhtguy on Mon Dec 13, 2021 11:44 pm; edited 7 times in total
Posted: Mon Dec 13, 2021 8:45 pm    Post subject:
I'd get new stuff. I think MCM Electronics still make it. Very few manufacturers used tinted glycol, the larger Sony 12XX sets did, that's about the only place you'll find it, is out of an old tube.
ANy kind of air pressure in the one hole, to blow the coolant out of the other will do. I used to tip the tube upside down, then found the compressor was a lot faster (and messier!) Smile
that1crzywhtguy
Posted: Mon Dec 13, 2021 8:55 pm    Post subject:
Okay, so how do I tint the new stuff, and do I just eyeball it?
Posted: Mon Dec 13, 2021 10:27 pm    Post subject:
See our procedures here: http://www.curtpalme.com/Advanced_Procedures.shtm
Tinting glycol is one of them.
Note that if you have an liquid coupled projector it's the c-element that's tinted, not the glycol.
that1crzywhtguy
Posted: Mon Dec 13, 2021 10:31 pm    Post subject:
Oh cool thanks. I'll maybe try filtering it first to see how that goes. Although for the blue tube it's easy, cause it's not tinted and is the worst offender!
-Cheers
Posted: Mon Dec 13, 2021 11:34 pm    Post subject:
What projector do you have?
that1crzywhtguy
Posted: Mon Dec 13, 2021 11:44 pm    Post subject:
I was initially asking about general practices, but I guess this got sorta specific so I updated the title with the unit in working on. Sony VPH-1042Q.
Posted: Tue Dec 14, 2021 12:53 am    Post subject:
Ok, so a very old unit, so definitely doesn't have c-elements let alone tinted c-elements. May or may not have tinted glycol. Not sure what they came with originally.
As I mentioned earlier this tinting glycol hints may help: http://www.curtpalme.com/Tinting_Glycol1.shtm
I wouldn't be overly concerned with perfection given the age and the limits around the projector you're using. You could also go completely untinted and it may not be that bad. YMMV. Good luck!
that1crzywhtguy
Posted: Tue Dec 14, 2021 1:07 am    Post subject:
Thanks for the advice! Yeah I'm not worried about perfection at all, but the blue tube is absolutely riddled with crystals. The red looks very cloudy. The tube condition looks fantastic though, so that's a big plus! I think I'll just try filtering and see how it goes. Seems low risk. If I'm not pleased with the results, I'll buy some ink and swap em all out!
Posted: Tue Dec 14, 2021 1:16 am    Post subject:
Hey I have two of those projectors. Love them at Halloween.
https://www.youtube.com/watch?v=NN7H_2ziBQU
that1crzywhtguy
Posted: Tue Dec 14, 2021 1:43 am    Post subject:
Nice! Lol
Posted: Tue Dec 14, 2021 4:21 am    Post subject:
https://www.youtube.com/watch?v=F3q-wd6CWYs
that1crzywhtguy
Posted: Tue Dec 14, 2021 7:21 am    Post subject:
Wait, you have 4 of em!???
Posted: Tue Dec 14, 2021 7:44 am    Post subject:
No just 2 1040's. The bottom windows were JVC DILA projectors. Also have a pair of 12xx series SONY's there. a 1272 and a 1251 I believe.
Here's where I used the 1272 because it can do black not like a digital blocking light with its panel:
https://www.youtube.com/watch?v=ihQCyXC9rMk
This is green tube on only so the RGB alignment wouldn't affect anything because the Scrim ( screen ) was blowing in the wind a little causing the beams to go into 3 RGB shadows. Solution was to turn off the red and blue tubes.
BTW this was after the rain leaked into the top keypad on the projector. Fortunately I had a roll of blue shop towels and a Honeywell fan with me. Wink it didn't stop raining the whole time from 4pm on-wards. Didn't loose a single piece of equipment.
I use allot of JVC's now. I picked up a bunch from Disney World surplus as well as 3 or 4 more before that some c. 1999-2000. and some c.2005-2006
This years fun 2021: https://www.youtube.com/watch?v=8Bilv45toR8
2018 was our best year: https://www.youtube.com/watch?v=eR0dGklOKXc
