Corleone88
| Posted: Fri Nov 05, 2021 7:00 am Post subject: Barco and a burning smell... |
I made a mistake after putting back the focus H shift board. I started to smell burn after starting the Barco. I turned off the projector and removed the board. One of the pin was bent. I saw a black stain both on the board next to the damaged pin and on the main horizontal board. I do not know what to do next Sad. I have a spare board, can I plug it in and test or is it too dangerous?
The main board seems very difficult to change...
| Posted: Fri Nov 05, 2021 6:02 pm Post subject: |
Straighten the pin and plug the board back in. Most likely you'll be fine.
Corleone88
| Posted: Fri Nov 05, 2021 7:29 pm Post subject: |
After checking, the pin is cut in half. I swaped with another focus H shift board. The 1209s is back and seems fine. Thanks a lot Curt !
