Moome
innof
Posted: Sat May 08, 2021 2:24 am    Post subject: Moome
Hello again folks.
Based on some reading here from past forum threads, I am surmising that Moome had different versions produced for his HDMI Marquee cards.
How do you identify which version one has?
And, what was the latest version made?
Cheers!
Posted: Sat May 08, 2021 1:26 pm    Post subject:
Latest version is the one here (v3): http://www.curtpalme.com/VIM-FULLHD.shtm
V1 to V2 difference: http://www.curtpalme.com/docs/Moome_v2_card_comparison.pdf
innof
Posted: Sat May 08, 2021 2:27 pm    Post subject:
Good morning Kal. And, as always, thank you very much for the kind reply.
By visual comparison, my cards looks like the latest one in the link provided (version 3).
However, I am compelled to ask if the older models (version 2) also had the white "1080P FULL HD" markings across the front of the unit?
Otherwise, how would you proceed in distinguishing them?
Cheers!
Posted: Sat May 08, 2021 3:11 pm    Post subject:
Not sure. Is there not something silkscreened on the PCB with the version number?
jask
Posted: Sat May 08, 2021 7:28 pm    Post subject:
that printing is on Full HD units ( V2 ) from back in 2009. The extra capacitors and other board changes as well as the extra buttons on the remote are the best way to differentiate v2 from v3
https://manualzz.com/doc/18431607/vim-vim----fullhd-v2-fullhd-v2-hdmi-v1.3
innof
Posted: Sat May 08, 2021 11:56 pm    Post subject:
Hello again folks. Well, most astute of you as usual Kal; I did pull the module from the projector and it says "Ver 0.2" so I am going to assume that it is a Version 2 (?)
The remote control that it came with has a white silkscreen with "PJI-HD" (RC-001) on the front; Does this help to confirm the version?
Thank you again to all!
Posted: Sun May 09, 2021 2:02 pm    Post subject:
I'm not sure actually. Can you post a few pictures including the card circuit board and the remote?
innof
Posted: Sun May 09, 2021 6:02 pm    Post subject:
Hello again to everyone.
Here are some pictures which I managed to take today of both the remote and the actual board.
Thank you.
 Filename:  Moome HDMI.jpg
 Filesize:  486.85 KB
 Downloaded:  314 Time(s)
 Filesize:  486.85 KB
 Downloaded:  267 Time(s)
innof
Posted: Sun May 09, 2021 6:04 pm    Post subject:
Here is a picture of the remote control
 Filename:  Moome remote.jpg
 Filesize:  475.8 KB
 Downloaded:  291 Time(s)
Posted: Sun May 09, 2021 6:48 pm    Post subject:
That's definitely a V2 board. V3 didn't start shipping until 2010.
innof
Posted: Sun May 09, 2021 11:54 pm    Post subject:
Hi Kal. Thank you very much for confirming, I do sincerely appreciate it.
So, in its ultimate sense, what am I missing out from Version 3?
And, is it worth my wiles to seek one out... (?)
Cheers!
Posted: Mon May 10, 2021 12:01 am    Post subject:
See the “what’s new in version 3” on the order page:
Whether it’s worth upgrading is entirely up to you.
innof
Posted: Mon May 10, 2021 12:16 am    Post subject:
Hi Kal. I did take a moment to scrutinize the details as are outlined in the link provided and an important qualification was not necessarily elaborated in detail.
When referring to Dolby processing, does it mean that version 2 will pass pass a Dolby / DTS signal ?
Or, moreover, was it meant to specifically convey that Version 3 can process the HD (lossless) version of the Dolby / DTS variety (?)
Thank you.
Posted: Mon May 10, 2021 1:41 am    Post subject:
From the order page:
DTS-HD / Dolby True HD lossless audio support: Allows you to use an HDMI receiver or pre-amp between your Blu-ray player and projector to decode lossless audio. Previously this did not work correctly due to the HDMI card's EDID. The EDID has now been updated so this will work.
innof
Posted: Mon May 10, 2021 1:52 am    Post subject:
Hi Kal. Yes, I read that. But, it unfortunately fails to address my rather pedestrian question; Despite this specificity, will a Version 2 card still effectively process "regular" Dolby Digital / DTS signal?
innof
Posted: Mon May 10, 2021 1:53 am    Post subject:
The caveat here seems to be the "HD portion of the equation; Is it referring only to lossless for the Version 3?
Posted: Mon May 10, 2021 12:24 pm    Post subject:
The version 2 card (and earlier) have an EDID that allows lossy Dolby Digital / DTS to pass.
The version 3 card has an updated EDID that allows lossy and lossless Dolby Digital / DTS to pass.
innof
Posted: Mon May 10, 2021 12:54 pm    Post subject:
Good morning Kal. Very well then, this is just what I thought; Thank you for confirming, it is much appreciated.
Albeit nice to have, for me this aspect is not a critical consideration.
Cheers!
