Marquee 8500 woes...
innof
Posted: Wed May 05, 2021 1:30 am    Post subject: Marquee 8500 woes...
Hello to everyone. So, I am watching tv and suddenly the image fades out an then back in; It does this 3 times over an interval of 10 minutes. Then, nothing.
I turn the projector off for a few minutes and try again - nothing. I do notice that the tubes are intermittently flashing with a corresponding buzzing sound. Any attempts at getting an internal images (crosshatch, menus) proves unsuccessful.
I have a spare VIM module which I swapped out and still nothing.
Now I am both disheartened and disappointed; This unit has brand new tubes 😶
I need some help please; What can be causing this? I did lift back panel up to visually inspect the board and cannot see evidence of anything obviously blown. I am concerned because if this does involve a complex intervention, I will likely be cooked.
Cheers.
innof
Posted: Wed May 05, 2021 3:53 am    Post subject:
Over a dozen views now. Am really looking for some guidance please. Cheers ⭐
walteritaly
Posted: Wed May 05, 2021 6:52 am    Post subject:
try to see which red lights come on on the back of the projector where the CLM is located and in front of the LVPS low voltage power supply
CRT's the best!! 1 "VDC Marquee 9500lc full model and franke yokes hfq 900 lenses"- Marquee 9500lc HD10 GT17 moome v2 - DVDO vp50 pro- Lumagen radiance mini.
barclay66
Posted: Wed May 05, 2021 8:04 am    Post subject:
If there are no indications resulting from inspection of the LEDs, it could be a faulty HVPS.
Posted: Wed May 05, 2021 1:00 pm    Post subject:
Hello
Inspect tube faces with flashlight, look for cracks. Remove the neckbeard covers, check for lit filaments (orange glow) Any ozone smell inside?
HVPS is likeliest problem, it may be arcing inside the bricked rubber section. I have most 8500 parts here.
Tim at E-Tech Systems
ehometech8022@yahoo.com
innof
Posted: Wed May 05, 2021 1:23 pm    Post subject:
Good day to everyone. And, Thank You Very Much for the replies here 👍
I am not receiving any error message indicators on the back of the projector (other than when I press any key on the remote control, the red "C" LED momentarily lights up and goes of as soon as I let go of whatever button I m pushing).
Based on the feedback provided here, I proceeded to remove the front cover where the lens are located and none of the LED's on the power supply with the fans are lit.
However, the power unit beside it is making an audible arcing sound..... It has a red wire covered in clear plastic attached to the back of it.
Here is a picture for your reference; Is this the HVPS? If so, would this involve a complicated swap out? I remember Curt cautioning me to never touch anything that has these of wires connected to it because the carry potentially lethal voltages.
And, what does a replacement unit cost?
Again, much obliged to all. It does appear that I am leaps ahead of where I was yesterday i👍
Cheers!
innof
Posted: Wed May 05, 2021 1:30 pm    Post subject:
I apologize, I am having a lot of difficulty attaching the phot. I hope you folks understand which module which I am referring to; It is model PTV 34 - X2294, Issue 3 (Spellman High Voltage / Part # 404251).
Thank you.
Posted: Wed May 05, 2021 5:14 pm    Post subject:
Hello
"It is model PTV 34 - X2294, Issue 3 (Spellman High Voltage / Part # 404251)."
Yes it is the high voltage supply.
It is harmless when power is unplugged. Easily replaced; a bayonet connector and some phillips head screws.
I have those here, $200 and postage.
Tim at E-Tech
innof
Posted: Mon May 10, 2021 12:20 am    Post subject:
Many Blessing to each and every one of you that very kindly and selflessly volunteered to assist me here, I am immensely grateful 👍
Be safe.
